Computer Punch Card? 69 Chevelle - Chevelle Tech
post #1 of 19 (permalink) Old Apr 6th, 19, 8:23 PM Thread Starter
Hello all - new owner, old car seeking assistance on decoding a punch card found in my Chevelle.
I am attaching a picture of the card which has 755 (bench seat) and 36 (Malibu) 67 (convert) in Bold print.
What I am hoping to learn is if there is some cross reference chart between the small punched holes and tiny numbers along the bottom.
Any help most gladly appreciated!
DJC996 is offline
post #2 of 19 (permalink) Old Apr 14th, 19, 9:02 AM
Woj
Phil
Re: Computer Punch Card? 69 Chevelle
This question has been kicked around here before, but I don't believe there has been an answer on decoding the punch holes. I used punch cards in programming classes back in the early 80's and I'd guess you'd need a punch card reader. As far as your card is concerned, you will find the interior code and body style on it and it should correspond to the body number on your trim tag. If it is from your car, it only verifies body style, interior code assigned to that body number. Phil Woj
Woj is offline
post #3 of 19 (permalink) Old Apr 14th, 19, 9:15 PM
Andy
first verify that it is from your chevelle, the body number should match the last five on your body/cowl tag-the fisher body number, if it doesnt it belongs to another chevelle. it is common for docs to be in other cars. there is limited decoding for the ibm cards. some have RPO numbers printed in the options section and some dont. some of the other numbers might match the body tag or even be on a build sheet if you are fortunate enough to have one. looks like a convertible (3667) with a black bench seat (755). hope this helps, andy
Andy
1969 Baltimore SS Chevelle
1969 Trim Tag Research (Ongoing)
More 1969 Chevelle data needed submit your info today
Contact: [email protected]
Information Security enforced
TC# 3135
ACES# 08305
SS69Chevelle is offline
post #4 of 19 (permalink) Old Apr 14th, 19, 9:21 PM
jerry
I've responded a couple times re: the punch cards. The punch happens at the intersection of the numbers across the top and the letters at the side. That punch would designate options such as M40, C60, B80 etc. I have 2 for my convertible, one is perfectly intact, the other is mangled a bit. The option codes match the car. Found both in the front bench seat bottom.
cheveslakr is online now
post #5 of 19 (permalink) Old Apr 15th, 19, 7:29 AM
What year/factory?
Pioneer4x4 is offline
post #6 of 19 (permalink) Old Apr 18th, 19, 2:10 AM Thread Starter
1969 - Baltimore
I have tried to read up on this matter but didn't find those prior queries & responses.
I know that the card I have photographed (above) is for/from my car as the bold numbers match. It was found under tge seat.
What I am seeking to learn, or really rather Find is some sort of 'overlay' with the verticle and horizontal markers.
While my card has tiny numbers along the bottom, I have neither top nor side navigators. I understand that holes will correspond to such triangulation, but I am missing one ir more axes.
Does anyone have a source for outside axes/parameters?
Thank you, the joy is in the journey!
DJC996 is offline
post #7 of 19 (permalink) Old Apr 18th, 19, 9:19 AM
1958 Punch Card, Build Record Sheet, and Dataplate Decoding
Not the same, but maybe a starting point.
Basically from the end, each column is 1 character.
post #8 of 19 (permalink) Old Apr 24th, 19, 9:42 AM
Woj
Phil
I recently found a website that allows you to make your own punch cards. I have several punch cards from my Baltimore Chevelles. I was able to punch numbers and letters across a card from the website to serve as a template. Then I printed a card on my printer, had to shrink it a bit to match up to my actual card. After laying the original card over the downloaded card, I was able to read the card. It basically punched out what was written across the top of the card. So, no revelations, just that the punched holes matched what was written on the card. I'll see if I can download them on this post. I used these cards years ago in school and it all makes sense. Phil Woj
Well, I can't post pix off my work computer. Here's a link to the punch card site: https://www.masswerk.at/keypunch/
Woj is offline
post #9 of 19 (permalink) Old Apr 26th, 19, 12:40 PM
If this used a standard IBM format it translates to
A52 B55 02
Don't know if this designates any codes. Could have other meanings if a different code format.
Hope it helps.
Sleeper '69 is offline
post #10 of 19 (permalink) Old Apr 26th, 19, 7:07 PM
Gary
A52 B55 02
Hope it helps.
How did you decode it? I also have an IBM punch card out of my car that I would like to make sense of.
GotGrunt is offline
post #11 of 19 (permalink) Old Apr 26th, 19, 7:45 PM
Woj
Phil
I will make a post with photos later this weekend explaining how to read the cards. I want to make sure the photos and explanations are easily understood.
Woj
GotGrunt likes this.
Woj is offline
post #12 of 19 (permalink) Old Apr 26th, 19, 8:28 PM
jerry
So, I guess nobody is excepting my explanation? Maybe my original 2 punchcards are unique and it just can't be that simple?
post #13 of 19 (permalink) Old Apr 26th, 19, 8:50 PM
Gary
Please post a picture of your punch cards. The one I have is identical to the one the OP attached. It has small numbers across the bottom (1-80) and no letters on the side.
GotGrunt is offline
post #14 of 19 (permalink) Old Apr 26th, 19, 9:44 PM
Phil said he would explain this with pictures. It's complicated. Pictures would help. Look up EBCIDIC code.
Cheveslakr, this doesn't dispute your explanation. What I posted is what is punched. They are codes. If they don't make sense I'll look again at the punches. Kind of difficult from pic.
post #15 of 19 (permalink) Old Apr 26th, 19, 10:27 PM
Picture is upside down. The solid lines down the card indicate separate categories. If you can read the letters at the top of those categories it may make more sense.
A52 B 55 02
Five Facts You Might Not Know About The Chevelle AG Jeff Home Page News 4 Jan 20th, 16 11:15 PM
My 66 Chevelle tune- experiences with vendors, parts and performance. bobbyz Chevelle Tech 26 Dec 7th, 13 7:22 PM
Post card from where your Chevelle may have been made. MARTINSR Bench Racing 8 Feb 19th, 13 2:44 PM
Good or bad price for Sheet Metal Items joeperl Body Shop 4 Oct 26th, 12 2:52 PM
Lost my team chevelle card. limerat Membership 4 Oct 21st, 12 12:05 PM
