need help 65 trim tag - Chevelle Tech
 3Likes
  • 1 Post By davewho1
  • 1 Post By Rich-L79
  • 1 Post By zman1969
post #1 of 9 (permalink) Old Feb 28th, 19, 10:54 PM Thread Starter
Rich
trying to help an older friend figure out his trim tag on 65 he just bought looking for info from bottom line
i found tinted windshield, 4 speed and rear antennae can anyone help out with what the #s mean? https://www.chevelles.com/forums/att...587722&thumb=1
69 T/A clone LS6 6speed under construction
69 R/S Z/28 302 4 speed Daytona Blk top
87 Trans am 383 1le brakes
64 chevelle wagon
15 ZL1
zman1969 is offline
post #2 of 9 (permalink) Old Feb 28th, 19, 11:33 PM
Re: need help 65 trim tag
I can tell you that 08A = it was assembled sometime in the first week of August, if you go to the upper right corner of the screen and clic on tech, you can find more info on the rest of the numbers. Good luck
Jeffs68ss is offline
post #3 of 9 (permalink) Old Mar 1st, 19, 1:39 AM
CHEVELLESTUFF
Jeffs68ss likes this.
David
davewho1 is offline
post #4 of 9 (permalink) Old Mar 1st, 19, 6:29 PM Thread Starter
Rich
thanks I looked at that already but it didn't explain what the 2&5 were meaning
64 chevelle wagon
15 ZL1
zman1969 is offline
post #5 of 9 (permalink) Old Mar 1st, 19, 7:27 PM
Rich
The 2 and 5 are just markers for different option categories. The useful information is the "W", "L" and "S" as well as the trim code "707" and paint code "S-S".
aimhard likes this.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
post #6 of 9 (permalink) Old Mar 3rd, 19, 12:55 AM Thread Starter
Rich
OK thank you he said car was low options can anyone speculate what engine one might have? car appears to have factory 12 bolt 327-300 hp or?
64 chevelle wagon
15 ZL1
zman1969 is offline
post #7 of 9 (permalink) Old Mar 3rd, 19, 12:05 PM
Frank
The only way that I know of that tells what hp the engine came with from the factory is to look at the Protect-o-Plate for that car.
1965 Malibu SS coupe ... 327ci, 4 speed, 3.73 posi
Driving a musclecar, "PRICELESS"
MalibuSeaS is offline
post #8 of 9 (permalink) Old Mar 3rd, 19, 12:45 PM
Rich
Or to have the numbers matching engine still with the car.
If the 12 bolt is original to the car (which can be hard to tell definitively) it pretty much means a 327. But which 327? No way to tell.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
post #9 of 9 (permalink) Old Mar 5th, 19, 12:34 AM Thread Starter
Rich
OK no motor/trans was bought as roller thanks all gives him a blank slate to build as he wants
LeoP likes this.
64 chevelle wagon
15 ZL1
zman1969 is offline
66 SS with fake trim tag keithb What's it worth? 72 Mar 16th, 16 7:14 PM
Trim Tag Finish ? 71-SS350 Restoration Corner 13 May 20th, 15 2:47 PM
1972 trim tag decoding? 72chevy2door Tag Team 5 May 26th, 14 2:02 PM
1976 El Camino trim Tag kilorider Tag Team 3 Nov 4th, 13 9:58 PM
Repo Trim Tag??? blwnrat Tag Team 7 Oct 25th, 12 12:43 AM
