'69 Decode help - Chevelle Tech
post #1 of 12 (permalink) Old Sep 10th, 05, 7:03 PM Thread Starter
'69 Decode help
I've been to the chevelle stuff site and can't find a couple of things off this trim tag. The L in the lower right and the the 02323 on the lower right.
Also I know this doesn't "prove" that the car is an SS, but are these options consisitent with an original SS car?
last question, the block was decked when it was rebuilt, I found a number above the oil filter that reads: high perf pa88 K14
does this give anyone a clue? is there another place around the oil filter to find a vin#?
Thanks in Advance!
Purs is offline
post #2 of 12 (permalink) Old Sep 10th, 05, 10:39 PM
Re: '69 Decode help
there maybe another partial vin stamped on the ledge right by the oil filter,hard to see in that area
uzdpartz is offline
post #3 of 12 (permalink) Old Sep 10th, 05, 10:54 PM
Re: '69 Decode help
I can't figure out what the second picture is but the rag joint upper flange is big block (bolt on rather than pressed on)
post #4 of 12 (permalink) Old Sep 10th, 05, 11:20 PM
Re: '69 Decode help
Here is some info, https://www.chevelles.com/shop/ss_ident.html
69ssmike is offline
post #5 of 12 (permalink) Old Sep 10th, 05, 11:27 PM
Dale
Re: '69 Decode help
Dean. Not so sure that's an absolute. I found this bolted on coupler on a 69 300 Deluxe w/307-4 speed car that's been to more than a few midwest-area shows the past few years.
TC Gold #92 ~ August 1998
* Build Sheet Data Collection
* Author:
DaleM is offline
post #6 of 12 (permalink) Old Sep 10th, 05, 11:32 PM
Dale
Re: '69 Decode help
Thanks in Advance!
That's because (1) nobody knows what they mean or (2) they aren't telling. Soon as I can find anything definitive, it'll be posted
* Author:
DaleM is offline
post #7 of 12 (permalink) Old Sep 11th, 05, 12:26 AM Thread Starter
Re: '69 Decode help
sorry, I couldn't get a very good pic. It's looks like a brace that attaches to the rear differential. I also saw some cross braces near the lower control arms. Is this the F41 suspension package?
I looked again on the vertical pad by the oil filter and I couldn't see or feel anything but a rough surface....
Purs is offline
post #8 of 12 (permalink) Old Sep 11th, 05, 12:28 AM
Re: '69 Decode help
[QUOTE=Purs] It's looks like a brace that attaches to the rear differential.
Those look like NO-Hop bars to me????
69ssmike is offline
post #9 of 12 (permalink) Old Sep 11th, 05, 8:59 AM
Re: '69 Decode help
The 02323 is part of what was called the DP SEQ NO, the number was anywhere from 8 to 12 digits long and they often only placed the portion of it that helped them ID this body along the body shop lines so that when it came into the body bank on the Chevy part of the plant, it got matched up to the order in the Data Processing System. Each car had a unique set of numbers. On Leeds cars and ONLY Leeds cars, the DP SEQ NO is the Body number + 02323. So the complete DP SEQ NO XXXXXX 02323. (You Leeds built owners with build sheets, look and you will see)
It was used for internal plant processing and has no useful info on the car. Those were similar to the bar codes of today.
DP SEQ NO - Data Processing Sequence Number
There are letters only lower body tag from seveal of the GMAD plants like Leeds (KC) and Baltimore. No one has any idea what they mean, some think SS but they have been found on cars that were not SS optioned. It likely has something to do with in plant building of the car since the GMAD plants were charged with built other GM models on same platforms (Chevelle, Tempest, Skylard etc).
elcamino is offline
post #10 of 12 (permalink) Old Sep 11th, 05, 10:56 AM
Re: '69 Decode help
The 2nd pic is an aftermerket add on used in stopping wheel hop and inprove traction. They are called ( no-hop ) bars. Edelbrock sell them.
ENGINES WITH AN ATTITUDE
828-302-4088
Proud Dad of a US Marine
3V Performance is offline
post #11 of 12 (permalink) Old Sep 11th, 05, 2:47 PM Thread Starter
Re: '69 Decode help
Did some company make these aftermarket back in the 70's? The reason I asked is this car was in storage for 22 years and nothing has been altered since it came out of hibernation.
Purs is offline
post #12 of 12 (permalink) Old Sep 13th, 05, 7:43 PM
Re: '69 Decode help
Yes but I cant remember the company name. They delt with GTO performance parts. H.O. performance or somthing like that. boy its been some time.
828-302-4088
This Thread is more than 5417 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Decode 72 VIN and trim tag Yello72 Tag Team 2 Jun 21st, 05 11:33 PM
Decode engine block jjsledd Tag Team 2 Jun 16th, 05 10:38 AM
71 ElCamino decode Jones El Caminos 1 Jun 1st, 05 11:22 PM
Can someone help me decode? Joeks Tag Team 5 May 23rd, 05 7:49 AM
More Carburators to Decode, Please Luis Tag Team 0 Apr 14th, 05 11:16 AM
