4l80e or t56? - Chevelle Tech
2012 General Tech Forum from 2012
View Poll Results: 4L80e or T56?
4L80e 50 31.45%
T56 109 68.55%
Voters: 159. You may not vote on this poll
 7Likes
post #1 of 64 (permalink) Old Dec 12th, 11, 6:27 PM Thread Starter
Shaun
Send a message via AIM to SS Shaun
4l80e or t56?
well i didnt know where to put this thread so i put it in here well i am asking for opinions here. which would you do? 4L80E trans (which i already have in the garage). or a t56? I have NEVER had a car that i have built be an auto and for some reason i am feeling like it needs to be a manual trans but i am stuck. The pros is i already have the trans the cons is my car is setup for manual which means i need to mod the tunnel for it right? the cons is i need to buy an auto shifter with the console, plus buy the shifter kit so it can match my 4 speed auto trans. t56 pros well 6 gears! can take a beating (i know because i have one in my rx7) has 2 over drives which is good for my 4.10 rear gears. cons i need to get a hydrolic setup and i have to cut the trans tunnel for the monster to fit in its place. so which would you guys pick?
2005 dodge magnum daily driver
1988 mazda rx7 LS6 swap
1969 SS work in progress
SS Shaun is offline
post #2 of 64 (permalink) Old Dec 12th, 11, 8:24 PM
Aaron
Re: 4l80e or t56?
IMO, you gotta have the "Man Pedal", you know, the one on the left
Kinda biased as I have a T56 in my garage already.
Yes, either way you're gonna have to cut the tunnel, not sure how much for the auto though.
Aaron
65 Chevelle HT,
65_LS1_T56 is offline
post #3 of 64 (permalink) Old Dec 12th, 11, 9:02 PM Thread Starter
Shaun
Re: 4l80e or t56?
really i have to cut the tunnel for the auto too! wow! well i guess if i have to cut it i might as well cut it for the t56 right...lol
SS Shaun is offline
post #4 of 64 (permalink) Old Dec 12th, 11, 9:23 PM
Frank
Re: 4l80e or t56?
The auto is going to depend on your engine mount height. It should fit with some light massaging if you use stock height mounts.
If you go with the BRP set up that puts the motor a few inches higher than the trans as to go up that much as well. (well at least almost that much)
rfrankb4 is offline
post #5 of 64 (permalink) Old Dec 12th, 11, 9:41 PM
Aaron
Send a message via AIM to SilverVelle
Re: 4l80e or t56?
should be a no brainer!!!
my Velle is an auto that i want to convert to manual!!! found a t56 locally but the guy want 1200 for it with 90K... but does come with LS bellhousing(dont have the LS motor yet) and hyd clutch master cylinder... havent even seen a 4l80E that isnt for a 4x4...
SilverVelle is offline
post #6 of 64 (permalink) Old Dec 12th, 11, 10:05 PM
Talking Re: 4l80e or t56?
Pro Touring = T56
nuff said.....
SC&C, Kore3, Detroit Speed, BBS, AI, TickPerf, Currie, Moser, Holley, Hellwig, Edelbrock, Mast, Wilwood, BP-Auto, StopTech, Ridetech, Hotchkis, UMI, Energy, AAW, B&B Classic's, PPG, Aeromotive, Canton, C&R, Sparco, Ididit, Spectre, Bridgestone, DakotaDigital, Alpine, RockfordFosgate
analyte is offline
post #7 of 64 (permalink) Old Dec 12th, 11, 10:24 PM Thread Starter
Shaun
Re: 4l80e or t56?
the 4l80e comes both 4wd and 2wd. I have my LQ sitting in the garage with the 4l80e right now and i am so worried that i am not going to be happy with it when i am done with it. i am in the hunt for an ls1 t56 but i am not having much luck as of yet. as for mounts i have no idea what i am going to do yet i am following a few build threads to see if i can follow along and do what they are doing. but i do know i want to have the motor and trans bolted together soon and thats my goal before feb 2012
SS Shaun is offline
post #8 of 64 (permalink) Old Dec 12th, 11, 10:26 PM
Aaron
Re: 4l80e or t56?
Originally Posted by analyte View Post
Pro Touring = T56
nuff said.....
Agreed.
Soooo, who voted for the auto in the poll??????? Show yourself! Lol.
Aaron
65 Chevelle HT,
post #9 of 64 (permalink) Old Dec 12th, 11, 10:46 PM
Re: 4l80e or t56?
Just finished my T56 Magnum install. Love it for my intended use. For just a cruiser or a dedicated drag car would have left it an auto. If they ever come out with a stand alone controller for the 6spd autos then maybe will switch back.
A big thing to consider is what type of speedometer you intend to run and how it will be adapted to the trans you choose. I went with a 5" electric speedo and have to build a new dash to make it work. I got it when I had an LT1 style t56 and it only had an option for electric. My new magnum has the option of running either electric or mechanical.
Wheres that money tree hiding and who forgot to water it?
72sbc427 is offline
post #10 of 64 (permalink) Old Dec 12th, 11, 11:29 PM
Vince
Re: 4l80e or t56?
i would suggest to keep it manual if it was a manual car...
and if it was an auto car that you might be better with the auto...
sounds like you want the manual more than the auto
VinceS427bb is offline
post #11 of 64 (permalink) Old Dec 13th, 11, 1:13 AM
Derrick
Re: 4l80e or t56?
[cough]tko 600[/cough]
-Hank Hill
novaderrik is offline
post #12 of 64 (permalink) Old Dec 13th, 11, 8:26 AM Thread Starter
Shaun
Re: 4l80e or t56?
i thought about the tko's but man they cost more then the t56 and you have to get all this adjustable clutch slave cylinder and all that stuff no thanks!
SS Shaun is offline
post #13 of 64 (permalink) Old Dec 13th, 11, 12:39 PM
SS Clone = DD
Re: 4l80e or t56?
start searching forums, guys are selling high mile complete cars cheap
search craigslist using GOOGLE:
ls1 and t56 for sale craigslist.org
http://www.google.com/#sclient=psy-a...w=1242&bih=906
04ctd is offline
post #14 of 64 (permalink) Old Dec 13th, 11, 1:38 PM Thread Starter
Shaun
Re: 4l80e or t56?
yeah i am searching on craigslist and ebay and even on ls1tech. so lets see what i find.
SS Shaun is offline
post #15 of 64 (permalink) Old Dec 13th, 11, 1:49 PM
Re: 4l80e or t56?
screw those slowmatics... boooooooooring
and whos ever gone to a car show and looked all over the car thinking it was sweet, looked inside and said "eh its an auto" and walked away?
71 Chevelle SS
383-TKO600
bdc1013 is offline
This Thread is more than 915 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
You may not post new threads
You may not post replies
