Values Of Torque Plate Honing - Chevelle Tech
2005 General Tech Forum from 2005
post #1 of 17 (permalink) Old Jun 9th, 05, 12:19 PM Thread Starter
This is a pic of a 454 block that has come in for some work as it only has about 3200 miles on it since the rebuild and it was making some lower end noises. We line honed it and squared and decked it flat and bored it and we blued up the 2 center cylinders installed the gasket and torque plate and went in for 6 strokes on each cylinder as you can see the results and look at the piston as it has blowby right to the oil controll rings as we could measure .003 distortion on the cylinders.
I am posting this as Gary from NY say there is no differance using a plate with what I have seen so far over the years I am a believer. I have done blocks this way and gone trade shows and guys are amazed at what a torque plate does to a cylinder and on the after market blocks the distortion is minimal compared to the OEM stuff.
Comments are welcome
Website is up and running
Machine shop tour
Monthly Specials
CNC BLOCKS N/E is offline
post #2 of 17 (permalink) Old Jun 9th, 05, 1:02 PM
Re: Values Of Torque Plate Honing
Nice pics Carl pretty "self explanatory" ,,
I don't think any comments can expand on the pics but what the hell
Here is the threads you are referring too:
https://www.chevelles.com/forums/showthread.php?t=92975
And: http://www.chevytalk.org/threads/showflat.php/Cat/0/Number/1227305/an/0/page/0#1227305
And, you showed a block that is normally considered pretty ridged compared to some,,,
That particular block isn't even on the list of ones recommended for torque plate usage so think of the ones that are,,,,,
I just did a 428 Ford FE & you want to see something move,, it was so bad the stones were chattering for about ten strokes
Here is what AERA has to say about the subject & this is from 1988,,
Torque Plate Use Recommendations
"While all engines would benefit, to realize an increase in performance and a decrease in oil consumption, the following list of engines should be finish honed with a torque plate to simulate the stress of the cylinder head when the engine is assembled.
Manufacturer Displ. (L) (CID) Comments
GM 2.0L 121
2.5L 151
4.1L 252 V8 Aluminum Cadillac
4.9L 301
5.0L 305 Late model Chevrolet
5.7L 350 Oldsmobile
6.6L 400 Small block Chevrolet
6.6L 403 Oldsmobile
Ford 1.6L 98 Escort
1.9L 116 Escort
2.3L 140 OHC engine
5.0L 302 Late model engines
5.9L 360 *
6.4L 390 *
* While these are not thin wall blocks, durability and oil consumption is improved when a torque plate is used during remanufacture. It is not required to use a torque plate to prevent piston scuffing as we have noted to be necessary with the GM 2.0 and 2.5L engines.
The AERA Technical Committee"
Mike (Wolfplace)
VISIT US AT
----John Wayne----
Wolfplace is offline
post #3 of 17 (permalink) Old Jun 9th, 05, 1:09 PM Thread Starter
Nice post AGAIN
Machine shop tour
Monthly Specials
post #4 of 17 (permalink) Old Jun 9th, 05, 2:08 PM
Could you go into a little more detail of what exactly we are seeing?
69 Ratt Vette is offline
post #5 of 17 (permalink) Old Jun 9th, 05, 4:20 PM
Can I ask a stupid question? Keep in mind that I have never built an engine, but I have destroyed one . If it's a good idea to use a torque plate when boring the cylinder then do you guys (meaning engine builders) keep the torque plate installed when fitting the rings?
'70 Malibu, 454 w/Brodix Ovals, TH400 w/10" ATI, 12 bolt with 4:11's
2013 ZL1 Camaro, Ashen Gray Metallic, No Mods YET
rednecks70 is offline
post #6 of 17 (permalink) Old Jun 9th, 05, 4:25 PM
Jerry
Sheesh, maybe GM didn't torque plate my 01 GMC 8.1L. That pos burns oil and rattles like a diesel.
Jerry
65 Beaumont
L96 6 Liter
Straub hyd. roller
Tremec 5 speed
blumont is offline
post #7 of 17 (permalink) Old Jun 9th, 05, 4:53 PM
In the original Chevy Power books, Chevrolet recommended installing a stack of washers and a bolt (torqued) in each head bolt hole if a torque plate wasn't available.
Ever tried that? Seems like it would be better than nothing, if you were doing an oddball engine that you didn't have a 'plate for.
Schurkey is offline
post #8 of 17 (permalink) Old Jun 9th, 05, 5:04 PM Thread Starter
I don't think you would get the full affect of the gasket ETC.
Machine shop tour
Monthly Specials
post #9 of 17 (permalink) Old Jun 9th, 05, 5:07 PM Thread Starter
We keave .006 to .008 to hone out and we have a junk block with different size cylinders for fitting the riings as it was done without a plate.
Good question
Machine shop tour
Monthly Specials
post #10 of 17 (permalink) Old Jun 9th, 05, 5:12 PM Thread Starter
Look under each bolt hole and you can see where the cylinder was destorted and actually measuring wih the bore gauge in the dark areas is th biggist part of the cylinders and they are .003 distorted and try to get rings to seal in that enviorment and with cylinders that far out of round you end up with premature ring land wear as well.
And look at the piston as you can see that the blowby and carbon went all the way down to the oil control rings
Machine shop tour
Monthly Specials
post #11 of 17 (permalink) Old Jun 9th, 05, 5:28 PM
Shouldn't we be seeing some vertical marks in the cylinders or did the hone take them out. I know it only had 3200 miles on it but it seems like that would be enough to see some marks.
Excellent representation, THANKYOU. What was causing the lower end noises??
gspan1830 is offline
post #12 of 17 (permalink) Old Jun 9th, 05, 6:27 PM
Smile Re: Values Of Torque Plate Honing
As a machinist and engine guy I can appriciate what you have demonstrated.......thats pretty bad to say the least..........somebody was asking about vertical marks.......they were removed by the hone if there were any.......somebody also mentioned honing w/plates and gaping the rings.....speaking for myself after honing with plates then gapping to specs I've never had a problem......most guys that build their own stuff ( that dont do it professionally) dont have plates to work with.....if it makes you nervous gap to the high side.............what say you pros'?
joespanova is offline
post #13 of 17 (permalink) Old Jun 9th, 05, 6:59 PM Thread Starter
We went from .030 over to .060 as we put it in the CNC machine and squared and decked it and rough bored it to 4.302 and it will be finished to 4.310 and for the noise in the lower end who ever assembled it wasn't very clean and the main line was 2.940 which was .002 over size as we also line honed it to 2.938 and we will resize the rods and check them for bend and twist as we will probably have to hone the pin bores out as well as we always find them to be on the tight side and balance the rotator. The crank had to be ground .020-.020. So when the customer puts it back together it should be a pretty good peice when it is done.
Thanks for your positive comment.
Machine shop tour
Monthly Specials
post #14 of 17 (permalink) Old Jun 9th, 05, 10:17 PM
OK, thought I would throw in a picture too. This Gen VI 454 was plate honed .005 over and fitted with JE +.005 pistons. It was then run 80 hrs in a boat with a BM 250 blower with 5 pounds boost. Today he had me hone it and did not want to use the plates. You can plainly see on the bore near the center head bolt holes where the hone did not touch the bore. This is another pretty visual example that bores do distort when torqued.
68 Camaro 505, TH400, 3.73, hyd roller, 049s
1/4 mile track----1.552---6.90/ 100.22---10.89/123.15
1/8 mile track----1.557---6.92/99.71
3500#, 2995 foot elavation
kamero68 is offline
post #15 of 17 (permalink) Old Jun 10th, 05, 12:15 AM
Enrique
Send a message via AIM to Slowpoke70 Send a message via Yahoo to Slowpoke70
Sweet! I like pictures!
1970 Malibu
355/TH350/3.36
Isky z25/Sportsman2/300-36/Summit Headers
Slowpoke70 is offline
This Thread is more than 5538 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Torque Converter/flex plate cover caputz24 2005 2 Jun 9th, 05 9:34 PM
torque converter & flex plate rendrikat 2003 1 Dec 3rd, 03 11:46 AM
Honing without torque plates - how much power loss? Unclepennybags 2003 16 Oct 21st, 03 8:48 AM
Torque setting for Flex plate Carnut108 2001 2 Aug 22nd, 01 8:47 PM
Torque converter/ flex plate Carnut108 2001 1 May 22nd, 01 6:16 AM
You may not post new threads
You may not post replies
