Hurst shifter mounting location - Chevelle Tech
2005 General Tech Forum from 2005
post #1 of 4 (permalink) Old Apr 11th, 05, 11:51 AM Thread Starter
Send a message via MSN to DRLs68
I've got a 68 and I'm converting it back to a 4-speed (previous owner converted it to an auto). I bought an m-21 and a hurst shifter. I mounted the shifter on the rear mounting location on the trans. Now I can't shift into 2nd or 4th because the handle hits the console. Console is in the stock location. This may be a dumb question but, Should I have a different shifter with shorter rods mounted in the forward location?
, 4 speed, 3:73 Posi
TC#3854
DRLs68 is offline
post #2 of 4 (permalink) Old Apr 11th, 05, 11:55 AM
Wally
Guest
Posts: n/a
Re: Hurst shifter mounting location
You can check what you have at mrgasket.com, there is information as well as what is contained in the correct shifter kit, copies of the original instuctions as well.
post #3 of 4 (permalink) Old Apr 12th, 05, 8:23 AM
the Chevelle Camaro Nova Hurst shifters normally mount in the forward position on the Muncie trans. The Corvette shifters mount in the rear position.
joe58 is offline
post #4 of 4 (permalink) Old Apr 12th, 05, 8:46 AM Thread Starter
Thanks for the replies. I have the wrong shift kit.
DRLs68 is offline
This Thread is more than 5566 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Hurst competition plus shifter usage ELLI 2005 3 Mar 31st, 05 9:12 AM
Hurst Spr. Shifter III and T handle - possible? dpfairchild 2003 0 Jan 28th, 03 9:57 PM
Shifter Hump Location von Body Shop 11 Nov 7th, 00 2:03 PM
Grafting a GM shift handle (round) onto a Hurst Gene Chas Tips & Fixes 5 Aug 27th, 99 10:06 AM
Hurst shifter probs. ChevelleMan 1999 -- 2 Jul 22nd, 99 4:37 PM
You may not post new threads
You may not post replies
