Chevelle Tech - View Single Post - Ignition 101
Thread: Ignition 101
post #9 of (permalink) Old Aug 17th, 07, 5:09 PM
onovakind67
Re: Ignition 101
One problem you might run into is the vacuum advance coming in at high rpm's if you develop much manifold vacuum up there. If you're into 2-bbl carbs this becomes a real problem, or if your VS carb doesn't work well.
onovakind67 is offline
