I posted this up on the Camaro board & figured I should probably get an opinion from you folks also.
I've been slowly collecting parts to build a 406.
So far I have a 509 block (that still needs to be machined), a Scat cast steel 6" rod-internal balance crank, a set of 6" Lunati rods, set of aluminum Pro Topline 200cc angle plug heads with 64cc chambers, set of 1.6 Comp roller rocker arms & a few other small pieces like ARP stud kits, etc.
Last night I ran across a good deal on a Scat cast steel 6" rod-internal balance crank for a 383. It's one of their lightened cranks.
So now I'm trying to decide wether to build a 406 with a factory 2 bolt main block & all the potential problems that may or may not occur with a factory block. Or play it safe & build a 383 with a 4 bolt main & what is probably a more stable block.
I'm a big believer in the more displacement theory but I don't want to put the time & money into what may be a short lived block.
Intended usage, is a fun street car ('78 Malibu) that must be well mannered & run on pump gas. Low maintenance is a high priority.
Now here's a curve ball... Lately I've been thinking about turbo's.
So... What do you guys think? I would really like to hear from someone who has built, thrashed on & possibly destroyed both.
I've had both. A 383 with 10.5-1 comp. and a 280* cam in a 73 nova. Car ran very well. Street manners were OK. Best 1/4 was a 12.72. Later I had a 74 nova with a 406, 9-1 comp. 273* (I think) cam. Drove the car all the time. Even on 100+ mile trips. Very well mannered, Best 1/4 was 12.18. The 73 was an auto with 3.08 gears and the 74 was a 4-speed with 3.42's I regularly pounded on both these cars. Shifted the 383 at about 7800 and the 406 at about 7500. The only issue I ever had with either was caused by me. The 406 had so much low end, I got into the habit of not downshifting when I made turns. I would lug the engine down to 700 to 800RPM then just hit the gas. This caused it to wear out two bearings. There was no damage to the block or crank. I replaced the bearings, Put about another 5-6K on the car then sold it.
I think there are pro's and con's with either. But the bottom line is, Like you said your self. There's no replacement for displacement.
The 406cid combo is extremely close to my planned engine build with the 2-bolt 509 block. The combo will live fine in the GM block but adding a turbo will be questionable. If you're really leaning towards the turbo idea, I don't see any reason to chance the 400 block. The 4-bolt 350 block will likely live longer at higher hp levels. The only replacement for displacement is power adders If you are unsure of the turbo idea, build the 406.
406. Make REAL sure the person doing the machine work knows what he is doing. Failure of 400 blocks has more to do preparation than any structural flaws. Must be plate honed properly. Must be balanced properly. Must be line honed properly. Don't take to the guy on the corner just because he is close. Shop around and find someone with a good reputation. Like you said, you don't want to do it over. If in doubt, send it to one of the guys that invest their time in this site. JMHO. You can read about satisfied customers on this site. You can also read horror stories about Bill Mitchell and his ilk. Go where the satisfied people are.
What size chambers in your heads?
If you are serious about the turbos, I'd go with a 350 block. Better gasket grip between the bores. Any size engine will make any amount of power with a turbo. A 1000 hp 350 is not unusual. When you get to those power ranges, any detonation can cause gasket problems.
I vote 406. I've had many over the years, and I believe the a 400 2-bolt splayed block is one of the best platforms for all around performance. That being said, all things being equal, the difference between a properly built 406 and 383 is about one tenth in the quarter. I just happen to error on the side of cubes based on personal preference.
That is exactly what I gained going from 388 to 410. About 1/10th. Same cam similar heads, same car, converter, etc. My power is at a slightly lower RPM with the 410.
I would go 406, you already have the parts. Heads are a little small though.
Like someone else said, get the machine work done by someone that knows what they are doing with a 400.
I guess I should've known what to expect from a bunch of big block Chevelle lovers.
The heads that I have are small chamber, 64cc I believe.
Piston selection & price favors the 383. Not as much available for a 6" rod 400. I'd like to keep the compression around 9.5 or 10 to 1 for a naturally aspirated engine.
The turbo is an after thought. I just happened to meet a few turbo guys & I'm real impressed with what they are doing. I've also been trying to learn more about the LS series engines for later on down the road.
Anybody know of a trust worthy machine shop in the Portland, Oregon area?
Don't know how I missed your chamber size the first time around. Small chambers and dished pistons make a nice setup. That being said, I still like flat tops that allow a large quench area for maximum turbulance. Keep your quench close, .035-.040" which ever way you go. If you go with hypereutectics, it can be even closer. The problem with most pistons is their short compression heights, leading to taking a lot off the deck surface to get good quench.
With aluminum heads, you should have no trouble with 10:1.
Not exactly sure what you were planning to spend on pistons or where you were looking, but check out SRP pistons. For example, have a look at part number 259620. Its a -21cc dish for a 6 inch rod 400 bored .030 over.
With a 64 cc head and around .040 quench give or take a little(which Id shoot for right around .040 as close as you can)....this piston makes roughly 9.9:1 compression, which puts you right around where you say youd like to be naturally aspirated. Depending on all the fine details and the actual piston/overbore, it can vary a little, which may equate to a hair more or less comp....but for the most part......this piston gets you right in that range youd like.
There are others out there as well.
Oh yeah, I too would use the 406. The 509 block is a great starting point. And yeah, the two bolt block is the preferred starting point for a 400 block. A good 509, 2 bolt block splayed for 4 bolts is definitely preferred over factory 4 bolts.
One last thought....if you did go the turbo route....Id still start with the 400 block DEPENDING on the power level you build for. Obviously if your thinking about some 1200 horsepower, higher rpm thumper it might be a half descent idear to start taking a look at aftermarekt blocks.....but a mild build with a mild amount of boost from a turbo that still makes good power is doable.
Id start with the larger bore 400 block(good breathing with the large bore), 3.48 crank(to make around 377 inches).....and the shorter stroke leaves even more room for a dish(meaning you can knock the comp down further to allow for boost). Some of the "shelf" pistons advertised for this sorta configuration can get you arond 8.75:1 with a -26cc dish and your 64 cc heads. And Im sure if you work with them....you can nock it down a little more without going to a larger chamber.....so that leaves some room for some boost.
Now we are getting somewhere. I believe the SOMENDER-SINGH grooves are simply a crutch for sloppy tolerances in engine building. Ideally, the piston should come within .001" from the head at all RPM. That promotes maximum turbulance. Putting grooves in the pistons simply makes it hard for the mixture in the grooves to burn. Running minimum quench requires research with any piston/rod/ring combo to get the pistons as close to the head as possible. That takes the kind of money that most people don't have.
The old Gurney/Westlake engines used an angled flycut on the tops of the pistons in an effort to increase turbulance. Two strokes use a squish band to achieve the same effect.
The lack of turbulance is what makes hemi's the combustion chamber of choice for fuel burners; You don't want to be compressing liquid fuel in a quench area.
The auto makers do have a problem with quench; they need to provide enough area for carbon build-up over time. It is also said to make engines noisier. Who cares about that? That is something most of us hobbiest need not concern ourselves with.
My present 406 is running the piston .005" out of the hole. I wanted .015", but I hated to take another .010" off the top of the block since we had to grind way too much off to use KB pistons.
If you haven't bought a crank yet, I would talk to Wolfplace about using a 3.810" stroke crank with the KB pistons to see if that could eliminate grinding a lot off the deck area. That's what I'm looking at for my next 406/415.
A lot of people don't like the KB pistons. I have one of the first sets they made for the 406, and I haven't had any trouble with them. I'm using them with .0025" clearance. Next time, I'll go .0015" and .010 quench. I'm not saying you should do that, but that's the way I'm leaning toward my next street engine.
Also, check out The Old One's website. http://www.theoldone.com/ Endon has done some interesting head studies, most of which make sense to me. I wish he lived next door. It's all about sucking the maximum amount of heat energy out of what we are burning. There is still room for improvment.
kirkwooden, if the piston comes within .001 of the head at TDC, isn't your quench .001? I know that's ideal, but with piston rock, etc., it's not really possible. I've run as little as .025 measured quench on a steel rodded street engine without any problems but you really need a good machinist to get that spot-on as you well know.
Jim Moore (posts a lot on Team Chevelle and Bracket Talk) likes to run minimum quench - as I recall, he said he had one where the piston left "witness marks" on the heads - and he jokes that it keeps your rods from stretching
Minimum quench makes power. Something to consider is the piston stops at the top of the bore. Although it looks like a violent stop, it really isn't. The piston is slowed quite gently at the top and bottom of the stroke. If it weren't, engines would self destruct almost instantly. So, when you run close quench, even if you tap the head slightly, nothing happens because of slow piston speed. I've also seen other peoples motors with witness marks from the pistons, and it hasn't hurt anything, but I've never done it on my own motors for fear that MY gaskets will compress to .035" instead of .039". I think that with hyper pistons and tight clearance, .010" is doable without problems. The main problem is most after market pistons have compression heights that are way to short and would require about a .060" cut off the deck surface. With a stock block, thats a lot of metal to remove.
JM: Yes, mine are hyper. I have a 7000 rpm NA "street" motor. Don't really need forged pistons. Hypers are quiet, hard as a goats head, KB's have generous valve reliefs, lots of information on their web site. A lot of people have had trouble with them, I haven't.
I don't think SCAT made that crank when I built my engine. I started on it in '88. I'm using a stocker. Some of them break, some of them don't. If I were rebuilding, I would go with SCAT stuff. Good enough for 600 HP. More than I'll ever make with my freaky FI.
I just got Harold's 501C2LUN (the old R10-R15 Ultradyne, Harold's favorite cam) installed today after it sat in the garage for a year. Can't wait till that is running again.
Some general advice: If you find working on things frustrating, NEVER install a Rev Kit on any engine you own. I've been putting this off for a year because the kits are such a pain. The good news is everything looks good, so the kit goes back in.
Go 406 and don't look back. Vizzard has hyped them up a lot and made some claims about some of them being able to go .080 over; but don't chance that move. I think that story might be like the 327's that can go .125 over. I have heared a lot of storys, even heard of people owning them; but can't give anyone to give me a casting number or show me one.
On a 400, the two bolt it what you want. The factory 4 bolt G.M. blocks be it 350 or 400 do not have a lot of material available for the outer bolts to mate to. On a 400 it is even worse due to the fact that the main bore is larger and the outer bolts are moved into a zone that is thin.
If you put a good set of splayed caps on, plug the deck, and build a cup style steam manifold, that factory block can take a lot. Ad some block hard and it is even better. As said above Machine shop is key.
As for the KB hyper pistons. I do not personaly use them if I am the one paying for the engine. They may work great for some applications; but I would not be building a 406 to drive to work. To me using a Hyper piston to save a few coins or avoid some piston sound on start-up is like saving money by not investing in a reserve chute or wanting to wear one cause it is not convienient all bunched up on your belly. You may never need it; but if you do, it is there. Once you see what can and does happen in either case, the decision becomes easy.
It's hardly a good comparison, but I've been pretty darn happy with the boat anchor sb400 (mine had to go .040 to be saved) I built for my '69 pickup. It has the small truck heads and a torque cam and it's run like a champ for 20k miles without any major problems. I went somewhat budget with Chevy 5.7 rods and cast pistons and a stock Chevy crank turned .010 under. I recently had the pan off to fix a major oil leak and it looked great inside. This thing would pull stumps and would be downright dangerous in a lighter vehicle.
If I didn't want to maintain reliability above all and didn't demand that it be able to pull 6000+ pounds when taking the Chevelle to distant shows, I'd probably replace the small truck heads with some nice aluminum heads and a real cam and it would be downright fun.
Go the 406 route and just make sure you get the right head gaskets and that you drill your 64cc heads for the required 400 steam holes. 64cc heads have a tendancy to crack between the exhaust and the spark plug or between the exhaust and the intake, so make sure to have them magnafluxed before you just throw them on, especially if they are 2.02/1.60 valve heads.
406 was the right choice for me. mine is a two bolt, scat crank, AFR 195's, solid flat tappet, rpm air gap. it's been a great motor and i've never had problems with it since rebuild 20,000 miles ago, though i only ever spin it to 6000.
You have insufficient privileges to reply here.
Related Threads
Team Chevelle
5.1M posts
115.9K members
Since 1998
