66 Chevelle: Return of the Aztec - Page 24 - Chevelle Tech
 20Likes
post #346 of 409 (permalink) Old Jun 29th, 16, 7:06 PM
Mitch
Re: 66 Chevelle: Return of the Aztec
Dang !! I was looking forward to seeing this at Des Moines.
I didn't know this was a conversion. The Z bar is quite particular to this vehicle and hard to find oem. The aftermarket pieces aren't as strong and tend to flex. If that is what you have, it could be part of the problem of not enough pedal travel.
I'll be at Des Moines with the '38.
cozmacozmy likes this.
70 Chevelle SS 396, M20 Oshawa built Z25 project.
66 Chevelle SS 396, Atlanta built 138 driver/project.
67 Camaro, ss/rs 350 LA built driver/project.
62 Impala SS with a transplant 409
1954 210 2 dr sedan 292 6 cyl, straight axle project
38 Chev coupe...355, 200r4, 8.5" 3.42 posi
69 Chev C10
89 R3500 roll back car carrier
Second_chance_SS is offline
post #347 of 409 (permalink) Old Jun 30th, 16, 9:56 AM Thread Starter
I will be at Goodguys Des Moines on Saturday (attending only sadly).
I'll look for your 38.
The herd of Chevelles is now down to 2 cars...
66 Malibu "SS396" look-a-like Hardtop Aztec Bronze built the way I would have liked to order it from the General.
66 Chevelle SS396 Hardtop Aztec Bronze (not a clone!) 4 spd bench seat awaiting restoration
66Broke is offline
post #348 of 409 (permalink) Old Jul 5th, 16, 9:12 PM
I had to re-attach the arm on my aftermarket z-bar, I think I might have some photos of the correct angle. I'll look.
Jim_66SS is offline
post #349 of 409 (permalink) Old Jul 12th, 16, 11:01 PM
Mitch
Brian, did you come out on Sat with the morning rain? We sat in the car or a building from around 6 am until noon, when it finally quit drizzling. We were there until 10:30 pm. The fireworks were great !
69 Chev C10
post #350 of 409 (permalink) Old Jul 13th, 16, 10:49 AM Thread Starter
Yep I was there, I didnt have enough time to see all of the cars though, as I had my wife and kids there, they wanted to leave at around 3 pm.
I didn't see your coupe, where was it parked? Of course I might have just walked past it and not realized what it was- so many cars you start to get overwhelmed.
66Broke is offline
post #351 of 409 (permalink) Old Jul 13th, 16, 6:56 PM
Mitch
We were on the grass in the park area, right off the pathway near the gazebo.
Friday was sunny and HOT and we had to park on the street. Saturday, was SUPPOSED to be sunny and hot too, so we went for the shade and didn't need it.
69 Chev C10
post #352 of 409 (permalink) Old Aug 2nd, 16, 3:59 PM Thread Starter
Well July is over and I am finally done with more distraction projects (painted my co-workers van after a fender bender) and rebuilt a wrecked 2013 Impala for my daughters first car (see my other thread in Body Shop). That car turned out awesome!
Anyway, Chevelle is back in the shop. I painted the tail panel satin black and I installed the tail lights/moldings etc on the rear end of the car:
Next I need to find and purchase a different Muncie tranny. Previous one was leaky and needed a rebuild I'm afraid.
While I'm at it I can figure out what's causing my clutch engagement issue.
davewho1 and L341970F41 like this.
66Broke is offline
post #353 of 409 (permalink) Old Aug 17th, 16, 4:12 PM Thread Starter
Rear bumper, bumperettes, CHEVELLE emblem, SS396 emblems all installed. I am really digging it!
Now I am working on the front Grille. I have painted and detailed every piece to make it as good as I can. The grill is an OEM grille that was severely weathered. Overall it was pretty straight but the aluminum was discolored (white) from oxidation and had several blemished and scratches and gouges in it.
I removed the anodizing using some chemicals and went through several levels of sand paper grits (started with 80 grit, then 150, 180, 220, 400 wet, 600 wet, 800 wet, 1000 wet, 1500 wet then moved on to some very fine steel wool, then buffed it and finished it off with some Mother's aluminum polish.
It really brought it to a level that it almost looks like chrome. I was super happy with the results.
I started putting the grille assembly together. Hopefully I can install it on the car this way- usually I install it one piece at a time onto the car but I think this might be the easier way to do it.
davewho1 likes this.
66Broke is offline
post #354 of 409 (permalink) Old Aug 17th, 16, 4:48 PM
Mitch
Dang, that looks great, Brian. You gonna drive it yet this year ??
69 Chev C10
post #355 of 409 (permalink) Old Aug 17th, 16, 5:31 PM Thread Starter
I really hope so. I need to diagnose my clutch problem then install a new (used) Muncie. That shouldn't take too long as long as the clutch issue is solved soon.
everything else is pretty much good to go.
I still need to:
- purchase and install the rocker moldings and wheel opening moldings.
- fix my clutch issue and install tranny/driveshaft etc.
- install fenders, hood, grille, etc
- finish up the wiring under the dash
- rear tires installed on 15 Inch steel wheels
of course there's a lot more to do but those are the major items I can think of.
66Broke is offline
post #356 of 409 (permalink) Old Aug 17th, 16, 5:32 PM
Looking gooood! I think the grill was installed as a unit due to the rivets. Not sure about the filler panel and head light assemblies; but that looks like a good way to go.
Jim_66SS is offline
post #357 of 409 (permalink) Old Aug 18th, 16, 3:46 PM Thread Starter
Thanks James.
I will give it a shot! easier to work on this stuff when it's sitting on saw horses.
66Broke is offline
post #358 of 409 (permalink) Old Aug 18th, 16, 4:44 PM
Love that color. It's gonna turn head for sure when you're done.
JohnC is offline
post #359 of 409 (permalink) Old Aug 18th, 16, 5:46 PM
Mitch
It's already turning heads....right here on the forum...
That's the same color I will have mine painted and Brian's looks very true to original. I just might have to drag mine to IA for the paint job...
69 Chev C10
post #360 of 409 (permalink) Old Aug 29th, 16, 4:39 AM
Agreed. Whomever mixed that paint did a great job! The guy who sprayed it did an OK job too!
Brian,
You may have listed it in the thread already, but what brand of paint is that? The car looks outstanding!
Pete 67 is offline
Closed Thread
This Thread is more than 1058 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
