The Next Generation - Page 35 - Chevelle Tech
 261Likes
post #511 of 641 (permalink) Old May 14th, 18, 11:56 PM Thread Starter
Devin
Re: The Next Generation
Originally Posted by f6john View Post
Hope you guys have found time to get this engine back together.
Not as of yet. We had a house fire in November, and are just getting settled back home but there's a lot of work involved. Haven't touched the engine since last post, and his daily is down, and the backup is giving trouble, just not much time right now. We'll be back at it as soon as we can.
Devin
Just an El Camino
Son's build:
My never-ending project:
64SS427 is offline
post #512 of 641 (permalink) Old May 18th, 18, 4:20 PM
I had a small kitchen fire 20 plus years ago and that really sucks. Good to know you are close to being back to normal.
f6john is offline
post #513 of 641 (permalink) Old May 19th, 18, 7:59 PM Thread Starter
Devin
Finished getting the cam degreed, timing cover and oil pan on today. New aluminum timing cover and fresh Summit oil pan this time around to hopefully avoid leaks.
Georgia69 and f6john like this.
Just an El Camino
Son's build:
64SS427 is offline
post #514 of 641 (permalink) Old May 20th, 18, 9:34 AM
Looks like weíre working in the storage shed, garage must be full!
f6john is offline
post #515 of 641 (permalink) Old May 21st, 18, 12:04 AM Thread Starter
Devin
Garage is full of house stuff, and both my cars in there are down with no time to remedy. The shed is the only available space, so that's where we are working. Normally everything would be prepped and I'd pull my car out of the garage to assemble, but that's not an option this time around.
Devin
Just an El Camino
Son's build:
64SS427 is offline
post #516 of 641 (permalink) Old May 21st, 18, 11:35 AM
Justin
sorry to hear about the house fire. hopefully you guys can get everything sorted out!
JF74chevelle is offline
post #517 of 641 (permalink) Old Jun 3rd, 18, 12:10 PM Thread Starter
Devin
Two steps forward, one step back. Took the oil pan and timing cover back off to install a cam button. A flat tappet cam shouldn't need it, but we recently discovered evidence that the cam had been walking in his previous motor. Cheap insurance. Checked valve to piston clearance, plenty. Then reassembled and installed heads.
Then he told me last night he was going to have to pull the intake back off, he ran out of sealant on the China wall and ended up with some gaps.
Devin
Just an El Camino
Son's build:
64SS427 is offline
post #518 of 641 (permalink) Old Jun 4th, 18, 9:13 AM
Excellent learning experience, some kids never get their hands dirty. This will serve him well the rest of his life even if he becomes a doctor, lawyer, or Indian chief and never has to touch an engine.
Proc likes this.
f6john is offline
post #519 of 641 (permalink) Old Jun 4th, 18, 12:49 PM
Duke
Absolutely true!! You are a good teacher, too!
DUKE 69 is offline
post #520 of 641 (permalink) Old Jun 5th, 18, 12:48 AM Thread Starter
Devin
We've done this probably 10 times in the last 5 years between his car and mine. He's confident and competent to do the job. New things I help him with, but right now I'm too tied up with the house to do much.
He has chosen to follow me into the automotive field for a career, which is a double edged sword. It's a compliment that he wants to do what I do, but I know the long term results he won't be able to escape.
Devin
Just an El Camino
Son's build:
64SS427 is offline
post #521 of 641 (permalink) Old Jun 10th, 18, 11:41 AM Thread Starter
Devin
Getting closer. Measured bellhousing runout yesterday, about .030. Way too much. We need to order some offset dowels and then I think it will be ready to go in.
Devin
joeyv69ragtop likes this.
Just an El Camino
Son's build:
64SS427 is offline
post #522 of 641 (permalink) Old Jun 10th, 18, 9:43 PM
Nice! Canít wait to see how it runs.
69 Chevelle 496/TH400
ET/Speed - 11.371 @ 117.23 - SOLD JUNE 2017
1965 Chevy Impala 355/TH350 - NEW RIDE JUNE 2017
Georgia69 is offline
post #523 of 641 (permalink) Old Jun 16th, 18, 11:07 PM Thread Starter
Devin
Today started with dialing in the bellhousing.
We got it within .007." Not bad considering that it started at over .030." Then we drilled and pinned the block for the offset dowels. Something I had not done before. These are Moroso brand, and they were not a press fit, just snug.
Then it was onto out with the old, in with the new.
I didn't take many pictures today, but this is where we stopped. It was a slow day, and we didn't make the progress we had hoped for.
The engine is in, cooling system is hooked up except we discovered that one drain in the block along the pan rail is missing, just need ignition, exhaust and fuel. Hopefully tomorrow.
Devin
davewho1 likes this.
Just an El Camino
Son's build:
64SS427 is offline
post #524 of 641 (permalink) Old Jun 17th, 18, 10:27 PM Thread Starter
Devin
More done today. Fuel system done, headers installed (after having to unbolt and lift the engine on the passenger side,) fan, pulleys, alternator in place. Filled with oil.
Went to prime the pump, only to discover there was no driver
Dang it. That makes everything we've done this weekend a waste of time
Devin
Just an El Camino
Son's build:
64SS427 is offline
post #525 of 641 (permalink) Old Jun 18th, 18, 4:38 AM
steve
what happened to the driver???
64tempestwagon is offline
