Getting back in the game. 67 Malibu - Page 7 - Chevelle Tech
 22Likes
post #91 of 95 (permalink) Old Feb 27th, 20, 5:39 AM
Re: Getting back in the game. 67 Malibu
Originally Posted by CTblown67 View Post
I have both depending on where Im going with it.
Much better, looks great.
67
70 (SOLD)
Alwhite00 is offline
post #92 of 95 (permalink) Old Feb 27th, 20, 5:38 PM
Freddy
Car looks great!!!
Freddy
Freddy Mercado is online now
post #93 of 95 (permalink) Old Mar 9th, 20, 7:25 PM Thread Starter
This isnt the first car I have built, but this is the one that has fought me the most every inch of the way, I have found the issue which was causing the car not to idle properly, which I thought was rich at idle and was carb problem. The intake gasket had been leaking and I took it for its first ride and blew the gasket out completely, pushng oil right of of the beather and smoking out of the right side tailpipe like a crop duster, its an easy enough fix, just wish I had found it before putting the motor in a freshly painted car.
CTblown67 is offline
post #94 of 95 (permalink) Old Mar 10th, 20, 5:51 AM
Pugsy
Damn.....that sucks.
PUGSY 69 El Camino, "CURSE" 5.3 Swap, 4L60e, 3:73 Posi
6.0L cam, 4.8L Flat Tops, 243 Heads
Fun, but not fast....14.7 @ 93.2 MPH
123pugsy is online now
post #95 of 95 (permalink) Old May 3rd, 20, 6:34 PM Thread Starter
I ended up adding front and rear Hotchkis sway bars, which made a huge improvement with the way the car handles. I also had to change out the pinion seal which even though brand new was leaking pretty bad, but was able to put a few hundred miles on the car to break the gears in so it was due anyways. Pretty sure I even found the last of the bolts I didn't tighten. I started working on the hood I didn't mind cutting this one as it had alot of damage when I got it, and I have a 2 inch cowl hood that I had painted with the car for when I end up with a motor that does not stick up threw it. today was a great day for a drive so I did just that, about 40 miles, and it was a great ride.
ID:	625628   Click image for larger version
ID:	625630   Click image for larger version
123pugsy and cozmacozmy like this.
