My 64 ground up - Page 8 - Chevelle Tech
 11Likes
post #106 of 130 (permalink) Old Nov 11th, 17, 10:42 PM Thread Starter
Michael
Re: My 64 ground up
Managed to spray a light coat of epoxy then 3M Body shutz then 3 coats of single stage Body color.
ID:	494450   Click image for larger version
ID:	494458   Click image for larger version
64 Chevelle
85 Monte Carlo SS
Mikes64 is offline
post #107 of 130 (permalink) Old Nov 12th, 17, 12:12 AM
Marcus
Re: My 64 ground up
Looks good!
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is offline
post #108 of 130 (permalink) Old Nov 12th, 17, 12:14 AM
rick
Re: My 64 ground up
Looking really sweet Mike , I wish I would have learned to do my own body & paint work
shovelrick is offline
post #109 of 130 (permalink) Old Nov 12th, 17, 11:47 PM
Gary
Re: My 64 ground up
Looking good. I see you like your rotisserie as much as I like mine. Keep up the good work.
You can't break it if it's broke to start with
saltygog is offline
post #110 of 130 (permalink) Old Nov 13th, 17, 7:32 PM Thread Starter
Michael
Re: My 64 ground up
Originally Posted by Malibu ss 64 View Post
Looks good!
Thanks Marcus
64 Chevelle
85 Monte Carlo SS
Mikes64 is offline
post #111 of 130 (permalink) Old Nov 13th, 17, 7:44 PM Thread Starter
Michael
Re: My 64 ground up
Well a second job to pay someone else probably would have been cheaper. Thanks Rick
Thanks saltydog, I've had the rotisserie borrowed for little more than a year, I'm going to owe him big time, well worth it though!
64 Chevelle
85 Monte Carlo SS
Mikes64 is offline
post #112 of 130 (permalink) Old Dec 1st, 17, 7:55 PM Thread Starter
Michael
Re: My 64 ground up
A little more painting over the holiday, all painted interior parts will have a satin finish, any tips on rotating pics?
ID:	499401   Click image for larger version
ID:	499409   Click image for larger version
64 Chevelle
85 Monte Carlo SS
Mikes64 is offline
post #113 of 130 (permalink) Old Nov 25th, 18, 8:18 PM Thread Starter
Michael
Re: My 64 ground up
[MENTIONTime to update, after the rearend was installed came the front suspension, Fatman drop spindles with UMI tubular upper and lower a arms, proforged tie rods and center link, and JGC steering box. Next came Wilwood 12” disc brakes. Then come the 6.0L and the 4L65.
ID:	579556   Click image for larger version
ID:	579558   Click image for larger version
64 Chevelle
85 Monte Carlo SS
Mikes64 is offline
post #114 of 130 (permalink) Old Nov 25th, 18, 8:35 PM Thread Starter
Michael
Re: My 64 ground up
After the the motor install I run brake lines, fuel, pressure and return, also the battery cable, from the trunk. After that the body was color sanded and buffed. This past week I removed it from the rotisserie and sit it on the frame, needs a little trans hump massaging with a bfh.
ID:	579562   Click image for larger version
ID:	579564   Click image for larger version
ID:	579566   Click image for larger version
64 Chevelle
85 Monte Carlo SS
Mikes64 is offline
post #115 of 130 (permalink) Old Nov 25th, 18, 8:47 PM
Logan
Re: My 64 ground up
Looking great!
64 Chevelle SS
logan64 is offline
post #116 of 130 (permalink) Old Nov 26th, 18, 4:05 AM
Marcus
Re: My 64 ground up
Looks very good!
post #117 of 130 (permalink) Old Apr 3rd, 19, 8:21 AM Thread Starter
Michael
Re: My 64 ground up
This needs a little update, I went with a Tanks Inc tank, in tank pump (225 lph), quick connectors at pump filter and steel connectors at the fuel rail. If anyone can tell me how fix these pics please chime in!
ID:	590786   Click image for larger version
ID:	590788   Click image for larger version
ID:	590790   Click image for larger version
Jeff65SS likes this.
64 Chevelle
85 Monte Carlo SS
Mikes64 is offline
post #118 of 130 (permalink) Old Apr 3rd, 19, 9:35 AM
steve
Re: My 64 ground up
Nice access door there! Beautiful car/build!
64tempestwagon is offline
post #119 of 130 (permalink) Old Apr 4th, 19, 7:51 AM Thread Starter
Michael
Re: My 64 ground up
Thanks Steve
64 Chevelle
85 Monte Carlo SS
Mikes64 is offline
post #120 of 130 (permalink) Old Apr 4th, 19, 8:12 AM
Re: My 64 ground up
Great looking build. Love the color.
Build thread-
Album -
Dan65ss is offline
