1966 Chevelle V6 build - Chevelle Tech
 7Likes
post #1 of 42 (permalink) Old Mar 29th, 20, 1:52 AM Thread Starter
Iíve been posting misc items and asking questions for a few years now and my build is a running driving car now so I thought I would post a thread about it.
Here goes....
First pic is the original 283 2-barrel and Powerglide coming out.
Second pic is the new LFX V6 engine/6L50e 6 speed auto trans as it arrived.
Third pic is where I had to cut the inside of the K member out to clear the pan.
Forth pic is the frame boxed in and with a 1/4Ē bottom plate.
ID:	620948   Click image for larger version
ID:	620950   Click image for larger version
ID:	620952   Click image for larger version
BURNN70 likes this.
66 Chevelle hardtop - LFX 3.6 liter 4 Cam V6/6L50 6 speed auto trans, 3.07 10 bolt, full Hotchkis suspension, Wilwood 4 wheel discs, white with red interior, cowl hood.
67_LS1 is offline
post #2 of 42 (permalink) Old Mar 29th, 20, 2:00 AM Thread Starter
Re: 1966 Chevelle V6 build
The sides of the LFX block are parallel so I built a wood box to duplicate the engine. A lot easier to handle.
Second pic is the box with the original Camaro mounts sitting on the original a Camaro subframe. This was just a double check.
Third pic shows the two sides on the K member are 90 degrees apart.
Forth pic shows that itís 45 degrees from block side to frame.
ID:	620956   Click image for larger version
ID:	620958   Click image for larger version
ID:	620960   Click image for larger version
67_LS1 is offline
post #3 of 42 (permalink) Old Mar 29th, 20, 2:06 AM Thread Starter
First pic is one of the block side plate out of wood because it was easier I than made them out is steel.
Second pic is one motor mount tacked up.
Third pic is of the frame getting loaded to go to the powder cost shop.
Last pic is frame when it got back, ready for assembly.
ID:	620964   Click image for larger version
ID:	620966   Click image for larger version
ID:	620968   Click image for larger version
67_LS1 is offline
post #4 of 42 (permalink) Old Mar 29th, 20, 2:12 AM Thread Starter
Full Hotchkis front and rear suspension and Wilwood disc brakes going together.
ID:	620972   Click image for larger version
ID:	620974   Click image for larger version
ID:	620976   Click image for larger version
67_LS1 is offline
post #5 of 42 (permalink) Old Mar 29th, 20, 2:14 AM
Michael
Who does your powder coating? Do they do brake calipers?
BURNN70 is offline
post #6 of 42 (permalink) Old Mar 29th, 20, 2:18 AM Thread Starter
Engine sitting in position. Exhaust down pipes with catalytic converters fit perfect and even lined up with the crossmember.
ID:	620980   Click image for larger version
ID:	620982   Click image for larger version
ID:	620984   Click image for larger version
67_LS1 is offline
post #7 of 42 (permalink) Old Mar 29th, 20, 2:22 AM Thread Starter
I had to cut the trans tunnel out because the 6 speed is HUGE. You can see the piece I cut out on top of the trans.
I then lowered the body back onto the frame to check fit.
ID:	620988   Click image for larger version
ID:	620990   Click image for larger version
ID:	620992   Click image for larger version
67_LS1 is offline
post #8 of 42 (permalink) Old Mar 29th, 20, 2:26 AM Thread Starter
Wilwood master cylinder. No power brakes.
Making a power steering line model from an old line.
ID:	620996   Click image for larger version
ID:	620998   Click image for larger version
ID:	621000   Click image for larger version
67_LS1 is offline
post #9 of 42 (permalink) Old Mar 29th, 20, 2:31 AM Thread Starter
I wanted to use the stock Chevelle floor shifter so I had to figure out the throw.
I made my own detent plate once I figured out how far the shifter needed to move to shift the trans.
The shifter mounts to a small kick out on the side of the tunnel.
ID:	621004   Click image for larger version
ID:	621006   Click image for larger version
ID:	621008   Click image for larger version
davewho1 likes this.
67_LS1 is offline
post #10 of 42 (permalink) Old Mar 29th, 20, 2:35 AM
Greg
I like it, very interested in how this will run. The best part is the choice of engine, it will raise an eye brow or two. I like the idea of modern power in old body, this should surprise more then a couple of guys thinking 6 cylinder, big deal.
Life is too short for caring about every bodies else's stuff
Grock-co is offline
post #11 of 42 (permalink) Old Mar 29th, 20, 2:36 AM Thread Starter
Once I got the body ack on I decided I didnít want to see the ECM so I had to extend the home run. I used the correct color combo and gauge for every wire. All soldered and shrink wrapped.
4 relays and fuses controlled by the ECM.
ID:	621012   Click image for larger version
ID:	621014   Click image for larger version
ID:	621016   Click image for larger version
67_LS1 is offline
post #12 of 42 (permalink) Old Mar 29th, 20, 2:42 AM Thread Starter
I cut and re-directed the upper radiator hose connection which allowed a simple all rubber ďSĒ.
Lower hose has a size change in the middle because I just couldnít find the right combo.
ID:	621020   Click image for larger version
ID:	621022   Click image for larger version
ID:	621024   Click image for larger version
67_LS1 is offline
post #13 of 42 (permalink) Old Mar 29th, 20, 7:59 AM
All of your work looks great. Looking forward to seeing more.
67
70 (SOLD)
Alwhite00 is offline
post #14 of 42 (permalink) Old Mar 29th, 20, 8:07 AM
Kevin
Nice fab skills. Very nicely done.
kmakar is online now
post #15 of 42 (permalink) Old Mar 29th, 20, 10:12 AM Thread Starter
E-Tech Powder Coating in Walnut Creek powder coated the frame for me. Iím not sure if they do brake calipers but I donít see why they wouldnít.
67_LS1 is offline
