A small trunk project - Chevelle Tech
 2Likes
  • 1 Post By Nazarah
  • 1 Post By Nazarah
post #1 of 8 (permalink) Old Feb 18th, 20, 2:21 PM Thread Starter
Matt
Send a message via AIM to Nazarah
This was my winter project this year. I know it's very small stuff compared to some of the stuff on here, but it was fun for me. And I think it came out pretty OK. Thought I'd share something new to look at.
I removed everything, and cleaned and painted the trunk floor. Repairing small holes where needed.
Then started with the cardboard for the trim pieces. I messed around with trying to do some side pieces that went into the wheel well and also a complete back piece but they all made the trunk seem even smaller than it was becoming to begin with, so I left them out. Just went with the floor and the front trim.
Picked up a different fuel cell, battery hold down, nitrous bracket and stripped / polished the bottle. Used T-Nuts on the under side of the wood panel to bolt everything down. Made up some different fuel lines and then get everything reinstalled again. I even carpeted the panel for the amplifier mount if you can see it clear back there between the bars.
I still plan to somehow secure the floor piece down to the actual trunk floor of the car for a worst case scenario protection. The day it was done it was around 50 degrees here in Nebraska. Warm enough for a test drive!
ID:	617024   Click image for larger version
ID:	617026   Click image for larger version
ID:	617028   Click image for larger version
Rosinbluth likes this.
Never stop learning!
Nazarah is offline
post #2 of 8 (permalink) Old Feb 18th, 20, 3:16 PM
Allen
Re: A small trunk project
Looks good
Got ta ask: Maybe I'm missing it but the way your battery cutoff is mounted I don't see how it's activated from the rear (outside the trunk/rear tail panel area) of the car. Please don't tell me that with those tubs, nitrous, etc... that you never frequent your local 1/4 mile track.
Blown1932 is offline
post #3 of 8 (permalink) Old Feb 18th, 20, 3:41 PM Thread Starter
Matt
Originally Posted by Blown1932 View Post
Looks good
Well - I wish I *could* tell you that....... But you are correct, there is no way to activate it from outside currently. It would not pass tech. There are probably no less than 100 things about this car that wouldn't pass tech I'm guessing. But I've never had any car on the track to speak of at all, so to be fair I'm not sure what it takes to pass. The only local track we have is an 1/8th mile, and that was badly damaged during a flood so I'm not even sure that thing is usable right now.
Blown1932 likes this.
Nazarah is offline
post #4 of 8 (permalink) Old Feb 18th, 20, 4:02 PM
Yep, looks a lot better IMO.
I have been doing wiring for years and this is just meant as a helpful observation but it looks like in your before picture you might have had a fuse on the main power wire and if so hopefully it got reused after the cleaning up and maybe placed behind the Optima battery ?.
Also too it looks like an old Rockford amplifier between the wheel wells and on your after picture if the small red wire off of the battery positive is for that amp, put a fuse on that wire close to the battery terminal. If the braided line were to rub through the red wire and there was not a proper fuse in the right place you could have some real bad damage to things.
One last thing is if you were to do some more work in the trunk, think about putting the Optima battery in a vented enclosure to where if it does become overcharged and vents, the fumes will be directed to the outside or underside of the car.
Always working on something:
Jim Streib is offline
post #5 of 8 (permalink) Old Feb 18th, 20, 4:40 PM Thread Starter
Matt
Good catch Jim!
Yes behind that red top is an ANL fuse mounted to the floor that the main wire all runs through. I have an inline fuse for the amp on the way from Amazon today. Of all the things it took to do this project, that small piece was one of them that I did not have on hand.
I'll take a peek at those vented enclosures. Never thought of that. And - probably an item that would help me pass tech one day!
Nazarah is offline
post #6 of 8 (permalink) Old Feb 18th, 20, 4:59 PM
Originally Posted by Nazarah View Post
Good catch Jim!
Just wanted to throw some things out to you.
I don't know if the Optima's need to be in an enclosure to pass a "tech" inspection at a track but if they do not I would add one anyway. Some of the tech rules I've seen are outdated like them like not checking or needing a main power fuse on the battery and then "thinking" the master on/off switch will cut all of the power when off.
I know WAY too many people think the Optima's are the shizzle and they cannot vent fumes but they can and while in a buddies car he had an old style battery like in your before photo, his regulator stuck and overcharged the battery filling the trunk with fumes. He was at a rest stop and opened the trunk and I could smell the rotten egg scent and before I could say anything, he twisted a battery connection to see if it was tight and it was not and then created a spark which then ignited the fumes with the battery exploding in his face. Not a good thing to happen at all.
post #7 of 8 (permalink) Old Feb 19th, 20, 8:40 AM Thread Starter
Matt
Dang. That is brutal. I can't imagine the aftermath of a battery exploding in someone's face.
As opposed to last year, I plan to put more than 100 miles on the car this year. I'll keep this on the to do list.
Sounds like alot more fun of a to do than chasing down the leak out of this TH400..............it's a never ending deal.
Nazarah is offline
post #8 of 8 (permalink) Old Feb 19th, 20, 12:24 PM
Very nice
Rosinbluth is offline
