Jeff 's 68 Chevelle 300 - Build Update! - Page 2 - Chevelle Tech
 46Likes
post #16 of 22 (permalink) Old Dec 25th, 19, 11:39 PM
Ben
Looking good!!
1968 300 likes this.
Ben R.
RAMBO is offline
post #17 of 22 (permalink) Old Jan 31st, 20, 1:18 AM Thread Starter
Re: Jeff 's 68 Chevelle 300 - Build Update!
Well after a month long fiasco with my 12 bolt I am finally moving forward with my project. Got the 4-speed tunnel welded in and seam sealed. Used some epoxy primer to paint the parts of the floor that needed it. Installed the factory style sound deadner and put the rubber mat and the rest of the interior back in. I have a 4-speed car now and I must say it looks like it came factory with a 4-speed. I was worried that the rubber mat would not want to fit over the hump but it went back in nicely! Going to make sure that all works OK then pull the motor. Seeing the light.
ID:	615074   Click image for larger version
ID:	615076   Click image for larger version
ID:	615078   Click image for larger version
davewho1, augy, glend123 and 2 others like this.
"Life is tough, but it's tougher if you're stupid."
1968 300 is offline
post #18 of 22 (permalink) Old Jan 31st, 20, 8:06 AM
Glen
Nice looking car!
1968 Chevelle
468 Big Block
Muncie M20 4 Speed
12 Bolt Posi 3.31:1 Gears
glend123 is offline
post #19 of 22 (permalink) Old Mar 16th, 20, 8:25 AM
love the steel wheels, great looking classic
Brian Whitby is offline
post #20 of 22 (permalink) Old Mar 16th, 20, 6:01 PM
I love the wheels with the dog dish hubcaps Four on the Floor with a bench too cool.
Plain Vanilla Chevelle. Simple and Classic!
Keep the updates coming.
1966Chev is offline
post #21 of 22 (permalink) Old Mar 16th, 20, 11:44 PM Thread Starter
Thanks everyone. I have pulled the motor. Just going to ring and bearing the bottom end as it all looks nice (58,500 miles on car and engine) then put my "hot rod" top end on. Got the block honed and if it ever stops raining we can get going again. Here is my Edlebrock C3BX manifold with new air cleaner and Accel coil. Chomping at the bit!!!!
ID:	619610   Click image for larger version
ID:	619612   Click image for larger version
ID:	619614   Click image for larger version
davewho1 and 68-13427 like this.
1968 300 is offline
post #22 of 22 (permalink) Old Mar 29th, 20, 10:49 PM Thread Starter
Motor is finally coming together. Almost have a full long block now. Check out my aluminum heads. JUST KIDDING. Just not painted yet. These are my camel back heads (462 casting) with Z28 springs and new valves (1.92). Motor got new rings and bearings. Hope it doesn't blow up.
ID:	621190   Click image for larger version
ID:	621192   Click image for larger version
ID:	621194   Click image for larger version
davewho1, VinceS427bb and glend123 like this.
1968 300 is offline
