Are there any frame mods that would help a LS swap? - Chevelle Tech
post #1 of 5 (permalink) Old Jan 25th, 16, 5:12 AM Thread Starter
Paul
Question Are there any frame mods that would help a LS swap?
I'm not doing an LS swap right now.
But I am doing a tone of work to my car including a new pro tour type frame.
I'm just trying to preplan and I could definetly see myself swapping to an ls in the future.
Is there anything I can do now that will save me a headache later?
454/T400/9" in a 67 Beaumont
Paul-ish is offline
post #2 of 5 (permalink) Old Jan 25th, 16, 5:36 AM
Re: Are there any frame mods that would help a LS swap?
I did not need to modify anything on the frame going to a LS.
67
70 (SOLD)
Alwhite00 is offline
post #3 of 5 (permalink) Old Jan 25th, 16, 4:22 PM
And if you think you need to, its time to explore other options. Sure you can do the standard boxing the chassis on a Chevelle which will help no matter what the power train is.
TC Member #96
19 Year Team Chevelle Member
1967 El Camino Build blog -
1967 Turbocharged 408ci LSx Chevelle - 1012 rwhp, 959 rwtq
2009 Supercharged Silverado -
"Hey Butthead, does this Pantera guy ever relax?" - Beavis
Brian Hoss is offline
post #4 of 5 (permalink) Old Jan 25th, 16, 7:10 PM
Paul, i chose to use a 95 impala gas tank, and had to cut about 3/8" of metal off of top and bottom rear frame rails to make it fit. I am going to box this area to maintain strength. This allows tank to fit with just a small gap between rails, and lets the tank sit up higher. I also cut a square access hole in the trunk pan to allow fuel pump replacement without dropping tank. This lets tank sit up higher also. Doesn't look too bad, and allows for additional fuel capacity. Big blocks suck gas so fast, but you gotta keep them fed. With an LS conversion with it's much better mileage,the bigger tank should yeild an impressive travel range..............
The Deejay is offline
post #5 of 5 (permalink) Old Jan 25th, 16, 7:47 PM
Bad Brad
Location: NSB Or Daytona Beach Shark Bite Capitol of the World
X2
I started with Nothing and still have All of Nothing!
TC # 2747 ACES # 7166
2009 AACA 1st Place National Junior Award
2009 AACA National Senior Award
ACES Chevellabration Top 3
2010 AACA First Place Grand National Award
1badss396 is offline
This Thread is more than 1585 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
