Recommended Swap Kits - Page 5 - Chevelle Tech
 4Likes
post #61 of 83 (permalink) Old Jan 13th, 16, 7:11 PM Thread Starter
Jorge
Re: Recommended Swap Kits
Todd,
I realize it's been a while. I've been checking the ls1tech forum on the motor mounts and am stoked to get those in the mail soon! Appreciate all your help thus far! I've got my 5.3 vortec, long tube hooker headers, 302-2 pan, forward mounts (on the way), and my wiring harness and ecu!
Will I need a 5" diameter power steering pump pulley to allow fitment with the stock truck accessory drive?
If anyone can weigh in, I'm also looking to learn about about other upgrades before putting the motor in. What are the benefits of putting in LS6 injectors, oil pump, and timing chain? LS7 lifters?
Thank you!
JSolo is offline
post #62 of 83 (permalink) Old Jan 13th, 16, 8:32 PM
Jason
Pulley depends on how far back the engine sets. The truck accessories are a couple inches forward from where the corvette accessories are.
If your changing the cam then I would get ls7 lifters, new oil pump, new timing chain. Otherwise I'd leave it alone. ls6 injectors may not work on a stock truck intake and fuel rail.
Jasons 69 Chevelle is offline
post #63 of 83 (permalink) Old Jan 14th, 16, 11:44 AM
Todd
Originally Posted by JSolo View Post
Todd,
Thank you!
Glad to hear you are on-board with using the new Hooker A-body swap components. If you want to run the truck accessory drive set-up, you will be required to use a 6" maximum diameter pulley on the PS pump.
toddoky is offline
post #64 of 83 (permalink) Old Jan 21st, 16, 7:39 PM Thread Starter
Jorge
Awesome thank you!
JSolo is offline
post #65 of 83 (permalink) Old Jan 26th, 16, 4:30 PM
Todd
Hey jSolo, a little heads-up for you here...I noticed the forward position engine brackets have hit the shelf with only a quantity of 5 remaining out of the first batch, since most of them are allocated to fill back-orders that have been pending. If you want to secure a set, I would head over to the Holley website, or any reseller's site listing them, and place an order pronto. There's more coming from our supplier, but it will be a few weeks I'm sure until the next run becomes available. The stock position engine brackets should be hitting the shelf any day now as well.
toddoky is offline
post #66 of 83 (permalink) Old Feb 9th, 16, 4:55 PM Thread Starter
Jorge
Originally Posted by toddoky View Post
I not so sure about that, when do you plan on doing your swap? I can help out you a bit here even if you don't end up using Hooker or Holley products as I've validated fitment of TH400, 2004R, 4L60-4L70, 4L80 and T56 transmissions, both with and without the stock A/C suitcase, with the Holley,stock truck, F-body, GTO, and Corvette accessory drive systems and can tell you how to obtain your best fitment with any combination of these parts/components while achieving optimized U-joint angles. I'll give you some starting words of advise...do not use stock location swap plates to install your LS/4L60 unless you are willing to perform floor surgery to your floor and the base of your firewall. You can lower the rear of the trans down to avoid the surgery, but you'll end up with the same undesirable U-joint working angles reported by others. The cure for this issue that will enable you to bolt the engine and trans right in and obtain optimized U-joint angles at the same time without cutting the floor is to move the engine forward and the Holley 302-2 pan will allow you to do this. There are two sets of engine brackets coming out from Hooker and the forward-position set installs with the 302-2 and does this for you automatically. The other set of brackets are stock location and allow the same bolt-in U-joint angles to be achieved when using a TH350, TH400 or 2004R transmission.
Todd,
the 302-2 fits the 5.3 vortec motor without cutting anything, right?
JSolo is offline
post #67 of 83 (permalink) Old Feb 9th, 16, 5:19 PM
Todd
Todd,
Yes, it fits all the LS engine with the common 3.62" stroke crank.
toddoky is offline
post #68 of 83 (permalink) Old Feb 9th, 16, 7:56 PM
Todd,
Other than shortening the windage tray.
67
70 (SOLD)
Alwhite00 is offline
post #69 of 83 (permalink) Old Feb 10th, 16, 9:46 AM
Todd
That's correct, I was only including vehicle components on the exterior of the pan in my answer and not the installation steps it takes to install the pan.
toddoky is offline
post #70 of 83 (permalink) Old Feb 12th, 16, 6:25 PM Thread Starter
Jorge
Hey Todd,
Will this pulley work for me?
Chevrolet Performance Power Steering Pulleys 12568997 - Free Shipping on Orders Over $99 at Summit Racing
JSolo is offline
post #71 of 83 (permalink) Old Feb 13th, 16, 8:27 AM
Todd
Negative, that is a Corvette pulley. I would do some searching on ls1tech for an appropriate smaller diameter pulley that others have successfully used on the truck pump.
toddoky is offline
post #72 of 83 (permalink) Old Feb 13th, 16, 10:58 AM
I used Dorman 300-201 PS pulley.
67
70 (SOLD)
post #73 of 83 (permalink) Old Feb 17th, 16, 8:59 PM Thread Starter
Jorge
And the Dorman 300-201 pulley will work on an 03 5.3 vortec in the 68 chevelle?
JSolo is offline
post #74 of 83 (permalink) Old Feb 27th, 16, 8:47 AM
Todd
For anyone who's been waiting on the new Hooker stock transmission location engine brackets, they hit the shelf two days ago and have begun being shipped out.
toddoky is offline
post #75 of 83 (permalink) Old Apr 9th, 16, 2:44 PM
Todd, do you work for Holley?
72BlueSS is offline
This Thread is more than 1434 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
