Ls swap radiator - Chevelle Tech
 6Likes
  • 1 Post By Blackhawk
  • 1 Post By rmc65elco
  • 1 Post By B52bombardier1
  • 2 Post By andrewb70
  • 1 Post By Rick Dorion
post #1 of 9 (permalink) Old Jul 14th, 20, 4:04 PM Thread Starter
Gary
Ls swap radiator
I’m looking for a recommendation as to what radiator people are using on their ls swaps, would like a shroud and twin fans, for my project 72 Chevelle, with 5.3 and 4l60e.
post #2 of 9 (permalink) Old Jul 14th, 20, 4:15 PM
Re: Ls swap radiator
I'm using a Griffin setup that came with the aluminum shroud and 2-Spal fans. It fits great but haven't completed the swap so I'm not sure how it will perform.
1970 Chevy Chevelle
Budget Boys Speed Shop est. 2006
Former YearOne R&D Guy
cparsons is offline
post #3 of 9 (permalink) Old Jul 14th, 20, 5:52 PM
Cody
I used the LS swap radiator from Auto City Classic. With a Chevelle you could use the normal aluminum radiator and reuse the 5.3L radiator hose; with my Monte Carlo the hose would be too short.
https://www.autocityclassic.com/chevelle-radiators/
I have only run mine for a few minutes at a time, but we're running one in my dad's 67 Chevelle and haven't had overheating issues.
[email protected] likes this.
1971 Monte Carlo
Blackhawk is offline
post #4 of 9 (permalink) Old Jul 14th, 20, 5:57 PM
I used an Entropy radiator on the 6.2L LS swap in my '65 El Camino. It has dual fans and they are triggered by the LS computer. Really well (US) made. Keeps the LS cool. Here's a shot from the initial installation.
'65 El Camino - LS3 - Photos: Instagram @rmc65elco
rmc65elco is offline
post #5 of 9 (permalink) Old Jul 14th, 20, 7:03 PM
Hello,
For me, it is a “Cold Case” LS swap radiator purchased from Jegs and it is Jegs part number 359-GMA546AK - purpose built in size for an A-body. Fits under the stock, original top radiator plate. This has both inlet and output tubes on the passenger side and has a small inlet for the steam vent line. This radiator assembly also comes with a pair of electric fans and a tight fitting fan shroud through the two-row, 1.25 inch fins.
I'm very happy with it stuck in traffic on these very hottest of Louisiana summer days - cools my 5.3 with ease. If you are going to use an LS truck water pump, I can tell you what radiator hose part numbers I used if you need them. I'm also running a 13 pound magnesium anode radiator cap to minimize electrolysis between the iron block, aluminum heads and aluminum radiator.
B52bombardier1 is offline
post #6 of 9 (permalink) Old Jul 15th, 20, 7:23 AM
I went with the pricey C&R piece of art.
Build thread-
Album -
Dan65ss is offline
post #7 of 9 (permalink) Old Jul 15th, 20, 8:30 PM
Call up DeWitts. Amazing piece and I was very happy w the price.
KaiserLT1 is offline
post #8 of 9 (permalink) Old Jul 15th, 20, 10:44 PM
Andrew
Both dewitt and C&R are great. If you want the best fan solution, you need to go with the latest technology brushless fans from SPAL. There are two inexpensive OEM options, one for a C7 Corvette and the other from a 2015 Chevy Volt. The corvette is a large single and the Volt is dual 12" fans. Both are rated at 600 watts. You will need a PWM signal, but both fans have the PWM controller built in. I prefer to use Holley EFI and program the PWM output for the fans. I use this on my 67 Cougar LS swap, although with the C6 fan and external fan controller, which is old tech now...
Andrew
Instagram @projectgattago
I do remote Holley EFI tuning.
I deliver what EFI promises.
Please get in touch if I can be of service.
andrewb70 is offline
post #9 of 9 (permalink) Old Jul 16th, 20, 5:34 AM
I went with a DeWitt on my Bel Air. Just got the car on the road and it does a great job maintaining stable temps.
69 RS camaro, 410, M22 Autogear, 4-speed , 8 pt rollbar - SOLD
68 camaro - SOLD
67 Bel Air - LM7, AutoGear M23Z, C5 brakes, 275/40-18 all around.
Rick Dorion is offline
