First track outing.... - Chevelle Tech
 2Likes
  • 1 Post By Geo71
  • 1 Post By Geo71
post #1 of 5 (permalink) Old May 17th, 20, 11:49 AM Thread Starter
George
Finally got some seat time with the new LS combo. Somewhat disappointing, but nothing broke and it was fun. Weather was sunny, mid 70's and 69% humidity. Figured on working with timing and get the stumble out of the launch.
Started with 26* of timing and shifting at 6500, also tried 6000 but was too low. [email protected] 1.84 60' Added 2* each pass and ended up 34* [email protected] 1.79 60'
Started working on the carb squirters. Started with 31-35 pink pump cams and ended up with 40/37 same pump cams...ran a [email protected] 1.77 60'
Old 388 combo in similar weather would have been 11.90-12.00 range at about same mph.
Good start, now to work on the tune/ catalog and see what is happening. May just be the difference in how the converter is acting. Traps about 5800 so some more gear might be useful. 60" was 1.68-1.72 with 388 depending on weather.
Jeff65SS likes this.
'71 Malibu
355 [email protected]
125 [email protected]
100 shot [email protected]
Geo71 is offline
post #2 of 5 (permalink) Old May 20th, 20, 10:29 PM
Jason
Cool so it’s close to the 388ci with 364ci. Is that stock heads?
Jasons 69 Chevelle is offline
post #3 of 5 (permalink) Old May 21st, 20, 9:53 AM Thread Starter
George
Re: First track outing....
Yes, stock 862/706 heads other than upgraded trunions and valve springs. Motor came with 317s but were cracked. Friend gave me these...
'71 Malibu
Geo71 is offline
post #4 of 5 (permalink) Old May 23rd, 20, 8:56 PM Thread Starter
George
Think I figured out where the missing power was hiding I thought it should have....going thru the MSD 6014s software, there is a page for coolant temp...it was set to add 5* when cold then pull 8* when it warmed up..so as it was going down the track, the timing was getting pulled...set that back to zero and now it feels much more like it should even with timing at 29*.....see how it does tomorrow...
shelteredv likes this.
'71 Malibu
Geo71 is offline
post #5 of 5 (permalink) Old Yesterday, 10:02 PM
I have friend with a 99 camaro with a truck 5.3 in it with a Brain Tooley cam. He has only ran a best of 12.99.
Finally, I got him to advance the timing to 34* from 30*. He was running in the 13.20's before doing this.
He only has street tires and they are worn out.
I feel he would be right at mid 12's if he would get some tires and free up the suspension.
I have not really been impressed with mild LS stuff. Im very impressed with a stock LS and a turbo on it, but a cam upgrade and tune....dont see much there.
Aaron is offline
