5.3 oilpan? - Chevelle Tech
 7Likes
  • 1 Post By Jasons 69 Chevelle
  • 3 Post By Geo71
  • 2 Post By Alwhite00
  • 1 Post By Blackhawk
post #1 of 10 (permalink) Old Mar 3rd, 20, 7:05 PM Thread Starter
5.3 oilpan?
I'm installing a 5.3 in my 64 Chevelle and it has a F body oilpan on it. Will that pan work? I'm using ICT mounts.
RUFF1962 is offline
post #2 of 10 (permalink) Old Mar 3rd, 20, 7:17 PM
Jason
Maybe, there are better options out. I used a Fbody pan with those mounts no issues but I also have my engine as close to the firewall as possible.
RUFF1962 likes this.
Jasons 69 Chevelle is offline
post #3 of 10 (permalink) Old Mar 3rd, 20, 7:37 PM Thread Starter
Re: 5.3 oilpan?
I'm using the 350 trans and wanting to leave it in stock location so I can use factory trans crossmember and mount...
RUFF1962 is offline
post #4 of 10 (permalink) Old Mar 3rd, 20, 9:22 PM
George
Re: 5.3 oilpan?
Holley 302-2 or 302-3 worked on mine with t350. Everything stayed in the stock position.
'71 Malibu
355 [email protected]
125 [email protected]
100 shot [email protected]
Geo71 is offline
post #5 of 10 (permalink) Old Mar 3rd, 20, 10:19 PM
Re: 5.3 oilpan?
Used a Holley 302-2 on mine and it was money well spent.
64tempestwagon and RUFF1962 like this.
67
70 (SOLD)
Alwhite00 is offline
post #6 of 10 (permalink) Old Mar 4th, 20, 7:56 AM
Re: 5.3 oilpan?
I used the f-body pan and notched my cross member, am not using ICT mounts.
The drop down on the pan is very close to the cross member. Problem is the crossmember is very rounded, oil pan is very square. I've seen some people were successful in heating up the crossmember and clearancing it for the oil pan with a BFH. Just need to knock 2 spots that are closest to the edges of the pan.
I was going to run my engine forward until I bolted up my headers and had all kinds of clearance issues, reason I went the route of notching. Now my engine is back against the firewall. I can probably fit 2 finger widths between pan and frame all the way around.
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
post #7 of 10 (permalink) Old Mar 4th, 20, 5:08 PM Thread Starter
Re: 5.3 oilpan?
The Lord shined down on me today...Was told the pan on the 5.3 I got was a F body pan....well it looked like it had a small leak around the pan so I removed it and was happy to see it had Holley on the bottom of it. Don't know it its the 302-1 or -2 pan. The only numbers I could find on it was 70R150B.
RUFF1962 is offline
post #8 of 10 (permalink) Old Mar 4th, 20, 5:21 PM
Cody
Re: 5.3 oilpan?
It's pretty easy to tell by looking at them if you have a reference:
Though I'm going to guess it's a 302-2 in black?
1971 Monte Carlo
Blackhawk is offline
post #9 of 10 (permalink) Old Mar 4th, 20, 5:27 PM Thread Starter
Re: 5.3 oilpan?
it looks like the 302-2 its silver
RUFF1962 is offline
post #10 of 10 (permalink) Old Apr 10th, 20, 9:11 AM
Re: 5.3 oilpan?
Looks like it is a 302-2 to me as well. Good luck on that one, should fit great.
Build thread-
Album -
Dan65ss is offline
