65 LS engine swap headers - Chevelle Tech
post #1 of 7 (permalink) Old Jan 6th, 20, 10:40 PM Thread Starter
LS engine swap on 65 looking for ceramic coated long tube headers.
Any suggested headers?
Kitch is offline
post #2 of 7 (permalink) Old Jan 7th, 20, 8:46 AM
Re: 65 LS engine swap headers
My Hooker Blackheart LS headers fit my 70 El Camino perfectly but they are not ceramic coated. But it should be easy to get them coated.
B52bombardier1 is online now
post #3 of 7 (permalink) Old Jan 7th, 20, 12:29 PM
I also used Hooker Blackheart LS swap headers on my 65. Used their engine mounts as well. Fit great! Not coated though.
Check out the Pro Touring section here on Team Chevelle, several build threads for 65 Chevelles going.... including mine.
Jeff Evans
65 Chevelle, LS3/T56 transplant in progress
67 Chevelle, ZZ502, AFR 305, Straub Solid Roller, 400 Turbo, Moser Rear 3.42 gear
Jeff65SS is offline
post #4 of 7 (permalink) Old Jan 9th, 20, 9:57 AM
My hedmans are nice but you have to put the engine ALL the way back to the firewall so they clear the cross member. Had to change out to a tahoe hydroboost setup as coils would not clear a vacuum booster.
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
post #5 of 7 (permalink) Old Jan 17th, 20, 10:09 AM
kenneth
I am using Speed Engeneering , but they are stainless . Fit very well , engine in stock location . Reasonably priced also , $375 . 1 7/8" primary tube , 3' collector .
1965stlhrsrdr is offline
post #6 of 7 (permalink) Old Jan 17th, 20, 10:31 AM
kenneth
Some pics
ID:	613742   Click image for larger version
ID:	613744   Click image for larger version
post #7 of 7 (permalink) Old Jan 20th, 20, 10:02 PM
Hooker headers all the way, their $$$ but fit great and very nice quality. I have a set on my 66 that are 1"7/8 primarys
OC66 is offline
