looking to do a LS swap in a 67 - Chevelle Tech
 7Likes
post #1 of 27 (permalink) Old Nov 15th, 19, 10:25 PM Thread Starter
I'm looking to do a LS swap in a 67 that I have. Looking for suggestions for the best LS and trans and the necessary hardware to do the swap. Any links anyone has where I can figure this out would be appreciated.
Roger Alred is offline
post #2 of 27 (permalink) Old Nov 15th, 19, 11:47 PM
leo
Re: looking to do a LS swap in a 67
roger, check this thread, Tom Rightler has it figured out!! https://www.chevelles.com/forums/11-...e-channel.html
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #3 of 27 (permalink) Old Nov 16th, 19, 8:29 AM
Hello Roger,
We recently had a very good discussion around here about LS swaps. Please try the link below:
https://www.chevelles.com/forums/43-...70-elc-ss.html
B52bombardier1 is online now
post #4 of 27 (permalink) Old Nov 17th, 19, 8:59 AM
There's several build threads on here, LS1Tech, etc. I'm doing a '67 LS swap (plus several other mods) currently so you can take a look at my build thread. As far as engine/trans it depends on what you want to accomplish. The trans selection will drive whether or not you'll have to modify the tunnel (i.e. T56, 6L80, etc - need to expand the tunnel vs. TKO600, 4L80, etc - minimal if any tunnel mods). The holley mounts/headers/oil pan fit really nice.
Also are you going to run fuel injection or carb? If fuel injection then you need to deal with the fuel system and ECM.
I hope this helps
67 Chevelle
58 Vette
69 Camaro
Build Thread:
rpol78 is offline
post #5 of 27 (permalink) Old Nov 27th, 19, 10:47 AM
CPP has nice adjustable motor mounts that worked out great also found that Doug’s headers are a good fit (collecters are a little close to floor boards) stroked LS3 / 4L70e
68Chevele likes this.
Byachvy67 is offline
post #6 of 27 (permalink) Old Nov 29th, 19, 6:53 PM
Id like to follow a recent 67 swap thread start to finish with allll the little nickel and dime stuff .Theres more to it than mounts and exhaust.
Byachvy67
your car wouldnt happen to have been owned and painted by a guy named Chris near la?
67_LS1 likes this.
cuisinartvette is offline
post #7 of 27 (permalink) Old Dec 2nd, 19, 2:41 PM
Roger, the "best" LS and trans will be determined by your budget, driving style, HP goals, and plans with the car.
You could spend $20K+ on an engine, then follow it up with a capable trans, or yank something out of a junkyard on a shoestring budget and make it work.
You have a ballpark budget? How will you be driving the car? Know what HP level you want to end up with?
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
post #8 of 27 (permalink) Old Dec 20th, 19, 11:09 PM
Russ
Using an aluminum block LS will take significant weight off the front end...
paul bell likes this.
pannetron is offline
post #9 of 27 (permalink) Old Jan 6th, 20, 9:38 AM
Roger
Checking to see if you have had any progress. I myself am looking to put an LS in my 71 Chevelle. So much info to intake.
Question for the guys.
I am on a cheaper budget. Local Salvage yard has LS truck motors for cheep complete with everything i.e. manifolds, front assembly's and ECM. So my ask is what recommendations on which LS version example 5.3L with opt LMG, LQ9, L9H. What is the best recommendation for these swaps. I am afraid 6.0's are a bit out of the price range with all the other items that has to be purchased for the project.
Not looking to burn up the streets here but make the velle a reliable cruzer.
Petey49 is offline
post #10 of 27 (permalink) Old Jan 6th, 20, 2:39 PM
Cody
Originally Posted by Petey49 View Post
Roger
Automatic or manual?
To keep it cheap and easy I would still go with a Gen III engine, a 4.8L LR4 or a 5.3L LM7. Then you don't have to deal with VVT, DoD, etc. The Holley swap kit is probably the easiest way to go for mounts and oil pan.
B52bombardier1 likes this.
1971 Monte Carlo
blackhawkMC is offline
post #11 of 27 (permalink) Old Jan 6th, 20, 7:18 PM
George
Lm7 for a 5.3 or Lq4 for a 6.0.
Holley 302-2 or 3 pan
LSX Innovations adapter plates and reuse your stock motor mounts.
ICT Billet alternator/ power steering kit for chevelle
Im doing vic jr carb and msd 6014. Pretty easy so far.
Holley Terminator X if staying efi...dont have to mess with pc reprogramming or harness mods...
'71 Malibu
355 [email protected]
125 [email protected]
100 shot [email protected]
Geo71 is offline
post #12 of 27 (permalink) Old Jan 6th, 20, 7:48 PM
Beth
I used all Holley parts to swap a 6.0L LS into my 68 Camaro.
The engine mounts are critical; the lower you can get the engine helps avoid cutting the trans tunnel.
Also setting the engine toward the front also helps.
nashville beth is offline
post #13 of 27 (permalink) Old Jan 13th, 20, 10:13 PM
I just finished this 67 Chevelle 300 Deluxe. 2002 5.3 with Muncie 4 speed. I am working on a 69 El Camino with a 2004 GTO LS1/4L65E. I also did LS1/4L60E swaps in a 64 Tempest(which I still own) and a 65 Lemans. The 65 Lemans I sold recently. I love doing these swaps!! I would be happy to answer questions. I have a list of the parts I used in the 65 Lemans swap. All 66 to 72 A bodys are going to be pretty much the same.
ID:	613560   Click image for larger version
ID:	613562   Click image for larger version
ID:	613564   Click image for larger version
sgregg51 is offline
post #14 of 27 (permalink) Old Jan 13th, 20, 10:18 PM
Here are the 64 Tempest and 65 Lemans. The 64 has A/C and the 69 El Camino is going to have A/C.
ID:	613568   Click image for larger version
ID:	613570   Click image for larger version
ID:	613572   Click image for larger version
sgregg51 is offline
post #15 of 27 (permalink) Old Jan 13th, 20, 10:37 PM
Drew
Love that tempest !
1sikride is offline
