6.0 build - Page 4 - Chevelle Tech
 27Likes
post #46 of 65 (permalink) Old Jan 20th, 20, 8:58 PM
Your 6.0 block is a 4.00 inch bore, you have to run a LS3 type head 5.3 and 4.8 have smaller bores. There are tons of heads out there yours probably came with the 799 castings like my 6.0 did. I know 243 and 823 are good ones but trying to find them can be difficult. I went with GM performance LS3 CNC ported heads they were $1800 fully assembled and flow just as good as AFR and Trickflow for a lot less $$$. My friend has a 6.0 Lq9 (which is higher compression than your's) with a LS3 top end and a comp cam and that car makes over 500hp. I would definitely upgrade the oil pump to a mellings since your going to be in there
OC66 is online now
post #47 of 65 (permalink) Old Jan 20th, 20, 9:28 PM
George
Re: 6.0 build
Im running the 862s from a 5.3 on my 6.0. See how it goes in the spring...may step up to something better later. Still should be around 500hp.
'71 Malibu
355 [email protected]
125 [email protected]
100 shot [email protected]
Geo71 is offline
post #48 of 65 (permalink) Old Jan 21st, 20, 7:40 AM
Re: 6.0 build
Originally Posted by JF74chevelle View Post
I thought Id update this thread. I got a summit 8707 cam, 226/238 @.50, 600/600 lift and 113 LSA. Got 799 heads that I am just going to to make reliable, .660 springs. I also got a seized complete 5.3 for $100 to take absolutely everything off of. LS7 clutch, cheap eBay exhaust manifolds because Im tired of messing with headers and dirty dingo adjustable motor mounts.
You'll have plenty of fun with the combo, good luck man.
The LS7 clutch is like butter, I really like mine, has not let me down yet. Using stock throwout bearing/slave and Tilton 75 series master. Have close to 14k miles on the combo, just flushed the clutch fluid, couldn't ask for a better setup.
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
post #49 of 65 (permalink) Old Jan 21st, 20, 7:36 PM Thread Starter
Justin
I thought I’d update this thread. I got a summit 8707 cam, 226/238 @.50, 600/600 lift and 113 LSA. Got 799 heads that I am just going to to make reliable, .660 springs. I also got a seized complete 5.3 for $100 to take absolutely everything off of. LS7 clutch, cheap eBay exhaust manifolds because I’m tired of messing with headers and dirty dingo adjustable motor mounts.
You'll have plenty of fun with the combo, good luck man. <img src="https://www.chevelles.com/forums/images/smilies/thumbsup.gif" border="0" alt="" title="Thumbsup" class="inlineimg" />
What throwout bearing are you using? LS7 or LS1?
JF74chevelle is offline
post #50 of 65 (permalink) Old Jan 21st, 20, 7:40 PM Thread Starter
Justin
799s and 243s are the same head. Going to have them milled for more compression.
post #51 of 65 (permalink) Old Jan 21st, 20, 8:17 PM
Stock LS1 with Speedway Motors extension hoses/bleeder setup. Love it, can bleed the clutch from the engine bay.
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
post #52 of 65 (permalink) Old Jan 22nd, 20, 1:07 AM Thread Starter
Justin
Great, do you know what part number it is for the master cylinder? I was thinking of running the stock 98-02 Camaro one but tilton might be better.
post #53 of 65 (permalink) Old Jan 22nd, 20, 7:42 AM
Re: 6.0 build
The problem I found with the f-body master was the funky angle you had on the mounting flange AND having to cut and weld the push rod after spending a fair chunk of $$ on it so it would fit our application. They're a lot of people running that setup though, you can buy a plate straight off of ebay that sandwiches in between your booster and firewall. I bought the plate but didn't end up using it. I made my own mounting bracket for the tilton using the 05 tahoe hydroboost mounting plate, a 2" pipe nipple for the body of the tilton, then a small piece of 1/4" plate and 2 bolts for the mounting face.
I'm running the .75" bore Tilton, I purchased the 75-750u so I had all the options when it came to mounting the reservoir and am glad I did. Went with the remote setup and have it mounted between wiper motor and hood springs. If you go this route make sure everything is final before you slide the hose on, it is a beast when it comes to gripping the barbs, once it's on it will never come back off without side cutting.
https://www.summitracing.com/parts/til-75-750u/
I'd started out using the ebay plate to create a flat plate for the tilton:
Realize that would have caused an extremely short pedal stroke, so cut the mounting flange off of it:
Would have to go back through my build thread to confirm downward angle, but here's the next to finished product minus paint. It's not sema worthy, but results speak for themselves, it's still working. Also got a small heim joint from Summit when I purchased the Tilton, threaded rod and coupling nut from the hardware store.
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
post #54 of 65 (permalink) Old Jan 23rd, 20, 2:07 AM Thread Starter
Justin
You had to cut the master cylinder and re-weld it on to the bracket at an angle?
post #55 of 65 (permalink) Old Jan 23rd, 20, 7:30 AM
Re: 6.0 build
No no no, I'm sorry if that was confusing.
The stock f-body master cylinder has an angled mounting flange on it.
If you use it you'll need to figure out a way to deal with that flange when mounting it to your car. There's plenty of aftermarket support for it. McLeod, Detroit Speed, etc.
I found this plate on ebay and purchased it, planning on using the f-body master, it would have worked fine:
https://www.ebay.com/i/281291998925?...caAiCQEALw_wcB
After I saw I had to cut the master pushrod and cut threads / weld / etc I went with plan B, the Tilton master cylinder. I was afraid I would heat up the brand new master and ruin it, the Tilton solved that issue.
I used the purchased f-body bracket as a template to create a flat bracket for the Tilton. Once I got it mocked up on the car, the tilton stroke is around 1". With the flat bracket the clutch pedal throw was very short.
That's when I mounted the tilton at a downward angle to give the clutch pedal enough throw. It's not perfect, some people will say it's wrong, but I've beat on it every way I can and it's still holding up fine.
If you do a search for fbody master cylinder bracket you'll find a lot of info on the web.
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
post #56 of 65 (permalink) Old Jan 23rd, 20, 10:41 AM
Troy
Re: 6.0 build
I'm setting mine up with the F body master. I got the kit from McCloud, included mounting bracket and ready to use clutch rod. Also came with a clutch pedal.
Sent from my SM-T720 using Tapatalk
Hotwire likes this.
66 CHEVELLE
senna is offline
post #57 of 65 (permalink) Old Jan 23rd, 20, 11:57 AM Thread Starter
Justin
I might need to get creative with my bracket since I have a 74 Chevelle so it may be a different firewall and I’m not running hydroboost brakes.
Senna, was this the kit you used? https://www.summitracing.com/parts/mcl-1434002/
post #58 of 65 (permalink) Old Jan 23rd, 20, 12:40 PM
Troy
Re: 6.0 build
I might need to get creative with my bracket since I have a 74 Chevelle so it may be a different firewall and Im not running hydroboost brakes.
No, that has a different master, looks billet.
66 CHEVELLE
senna is offline
post #59 of 65 (permalink) Old Jan 23rd, 20, 6:30 PM Thread Starter
Justin
This looks interesting
https://www.detroitspeed.com/tilton-...bracket-070434
post #60 of 65 (permalink) Old Jan 24th, 20, 7:50 AM
Re: 6.0 build
Still requires the angled bracket like I linked above though(read the fine print). But that's pretty much my setup in a nutshell. The billet neck they have is the pipe nipple I welded to the hydroboost bracket. Many ways to skin a cat..
Keep .75" bore as your target then mainly you just have to worry about the angle of the master and the length of throw you have at the clutch pedal.
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
