Whipple/Magnusson or other supercharger? - Chevelle Tech
 2Likes
post #1 of 16 (permalink) Old Sep 12th, 19, 1:01 PM Thread Starter
I have a 2006 6.0 L LS create motor that I want to super charge in the near future. My question is what manufacturer is the best choice in power/ dollar. My preference would be not to get deep in the internals if possible as it only has 300 miles on it, camshaft change for sure.
CDN67 is offline
post #2 of 16 (permalink) Old Sep 12th, 19, 1:16 PM
Re: Whipple/Magnusson or other supercharger?
In the late 2000s I had an '06 GTO and guys were raving about the Magnusson on stock engines. There were a lot of Prochargers too but those seemed to go best with forged cranks and pistons.
70 Camino...Roller
Tommy the Cat is offline
post #3 of 16 (permalink) Old Sep 12th, 19, 6:00 PM Thread Starter
My plan is a Whipple kit right now, but have time to get it best figured out.
CDN67 is offline
post #4 of 16 (permalink) Old Sep 12th, 19, 10:42 PM
Are your running a stock hood? If so make sure you have clearance. A maggie tvs2300 with jackshaft just barely clears. By the way I went maggie because you can overdrive them more without exceeding the bearing specs on the supercharger.
https://www.chevelles.com/forums/att...6&d=1478871079
Take a look at post 51 on my build thread.
67 Chevelle
58 Vette
69 Camaro
Build Thread:
rpol78 is offline
post #5 of 16 (permalink) Old Sep 13th, 19, 8:31 PM
Russ
The OEM piston top ring end gap is too small for a forced induction (or nitrous) power adder. I highly recommend opening up the top ring gap to something around 0.028" to minimize the chances of the ring ends butting together from the extra heat the s/c will create. If the ring ends do butt up against each other, they will jam the piston in the cylinder and lead to a pretty ugly sequence of destruction! If the block is iron, I'd also consider using ARP head studs instead of the GM head bolts if you do pull the heads to fix the ring end gaps. If the block is aluminum, the ARP studs might distort the block a couple thousandths requiring a slight overbore and new pistons...
pannetron is offline
post #6 of 16 (permalink) Old Sep 13th, 19, 10:52 PM Thread Starter
Thanks for the info. I was going to run the Holley front bias mount but after your post think the rear bias are the ones to use with all the Holley mounts so I can get it under the stock SS hood.
CDN67 is offline
post #7 of 16 (permalink) Old Sep 13th, 19, 10:53 PM Thread Starter
Good info, thanks. I have a 2006 6.0 LS2 motor aluminum block.
CDN67 is offline
post #8 of 16 (permalink) Old Sep 13th, 19, 11:29 PM
You might want to take a look at the corvette forum or the camaro5 forum. There's alot of builds out there running stock lower ends with pretty decent hp numbers. It comes down to how much boost you want to run. There's guys out there running 600+ RWHP with stock rotating assemblies.
Here's an article you might want to read
https://www.lsxmag.com/tech-stories/...rviving-boost/
67 Chevelle
58 Vette
69 Camaro
Build Thread:
rpol78 is offline
post #9 of 16 (permalink) Old Sep 19th, 19, 5:50 PM
Robert
I am building my 66 now, I decided to go with an LSA supercharger. Going to run a 2.5 pulley and should have enough power for anything I want to do.
pannetron likes this.
wyattroa is offline
post #10 of 16 (permalink) Old Sep 20th, 19, 1:41 PM Thread Starter
Sounds like a cool build. The Holly tech line told me that the rear bias mount should clear the blower under a stock SS hood. Iím gonna go to Magnuson blower as I can change of pulleys out and increase the boost with slight case clearancing.
CDN67 is offline
post #11 of 16 (permalink) Old Sep 20th, 19, 2:21 PM
Beth
Why not turbo it ? A single turbo can be an awesome dradstrip setup but I would change pistons fer sure
nashville beth is offline
post #12 of 16 (permalink) Old Sep 24th, 19, 2:33 PM Thread Starter
I have always loved the idea of twin turbo set ups, but the fabrication, part choices and street ability/heat is a concern. The car will not be a drag strip car so I feel supercharging may be the best way to go al5ough turbos are the way to make bigger power.
CDN67 is offline
post #13 of 16 (permalink) Old Oct 9th, 19, 4:41 PM
Sebas
I own a 403 stroker since 2 months and looking to add a power adder
Just can't decide if I go with the Vortech V7 ysi on the Whipple 2.9 ??
1971 Chevelle SS Clone, 403 LS Stroker
bodomram07 is offline
post #14 of 16 (permalink) Old Oct 10th, 19, 4:12 AM
Here's a Kenne Bell article that may help. It depends on where you want the HP/Torque.
Twin Screw vs. Centrifugal / Acceleration vs. Boost | Kenne Bell
Here's one from Redline Motorsports
https://www.redline-motorsports.net/...s-centrifugal/
67 Chevelle
58 Vette
69 Camaro
Build Thread:
rpol78 is offline
post #15 of 16 (permalink) Old Oct 16th, 19, 5:42 PM
I would explore the option of a procharger.
65 Chevelle Malibu 2dr HT LS Swapped
lsswapguide is offline
