Thinking of doing an LS swap - Chevelle Tech
 4Likes
  • 1 Post By Geo71
  • 1 Post By paul bell
  • 1 Post By 69-CHVL
  • 1 Post By Alwhite00
post #1 of 15 (permalink) Old Apr 5th, 19, 6:17 PM Thread Starter
Justin
I’m thinking of doing an LS swap into my 74. Planning to run a 5.3 NA, just heads and cam to get some power out if it nothing crazy really just want to have an awesome driver car.
What I thinking.
1) get a 5.3 either from local junk yard or eBay.
2) get the dirty dingo mounts to fit my Chevelle and mock it in place with my Muncie.
3) maybe run the edelbrock pro flo 4. Seems like a super easy and nice looking way to get it running and driving. I really don’t know how to wire in the harness from the engine into the car, seems like the most daunting task. I’ll probably run the stock accessories and figure out the power steering and all that.
Is there an easier way and cheaper way than going with the pro flo 4. Seems easy because you can use that harness that come with the kit to run the ignition and the fuel instead of having to mess with the stock harness.
JF74chevelle is offline
post #2 of 15 (permalink) Old Apr 5th, 19, 7:36 PM
Re: Thinking of doing an LS swap
Check YouTube. There is a guy who use to have a TV program that walks you through the whole process.
Slick87gn is offline
post #3 of 15 (permalink) Old Apr 5th, 19, 8:10 PM
Chuck Hanson
post #4 of 15 (permalink) Old Apr 5th, 19, 8:13 PM Thread Starter
Justin
Thank you
post #5 of 15 (permalink) Old Apr 6th, 19, 2:28 AM
George
Holley Terminator X.
I just started on swapping in a LQ4. But Im doing a carb, nitrous, t350 deal.
If I was doing the factory efi, the Term X is what I would use. Plugs in to all the factory sensors.
1970DreamCar likes this.
'71 Malibu
355 [email protected]
125 [email protected]
100 shot [email protected]
Geo71 is offline
post #6 of 15 (permalink) Old Apr 6th, 19, 2:50 AM Thread Starter
Justin
That does seem like a good choice. I’d be able to plug that into factory sensors then use the factory intake, coils, and injectors
post #7 of 15 (permalink) Old Apr 6th, 19, 7:15 PM
George
Originally Posted by JF74chevelle View Post
That does seem like a good choice. Id be able to plug that into factory sensors then use the factory intake, coils, and injectors
Lot easier than getting the stock computer tuned and modifying the harness, then having to find someone to tune it....plus it has progressive nos controller 2 step, boost stuff etc....
'71 Malibu
Geo71 is offline
post #8 of 15 (permalink) Old Apr 6th, 19, 7:33 PM
Fitech Ultimate LS, 70051 with trans control. Uses the stock sensors and DBC throttle body. $999.00.
Holley Terminator X Max with transmission contol if you need more bells & whistles like inputs & outputs for forced induction or Nitrous. $1,299.99. But has ONE o2 sensor, will not tune per side like the dual o2 Fitech system will.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #9 of 15 (permalink) Old Apr 6th, 19, 8:19 PM
OP, sorry, I see you mentioned a Muncie trans, you don't need trans control.
Fitech 70050, $795.00.
Holley Terminator X $999.99.
How may I help you?
1999 Trans Am-500hp
post #10 of 15 (permalink) Old Apr 7th, 19, 7:12 AM
Vince
Dual widebands really isnt needed IMO. My turbo mustang and EFI BBC dont have them and havent missed a beat is years.
paul bell likes this.
*2011 Mustang GT premium
*61" Scag Kohler 22hp 7mph
69-CHVL is online now
post #11 of 15 (permalink) Old Apr 7th, 19, 8:06 AM
Get the Holley 302-2 pan, you will appreciate it.
pannetron likes this.
67
70 (SOLD)
Alwhite00 is online now
post #12 of 15 (permalink) Old Apr 7th, 19, 1:55 PM
Andrew
The 74 A bodies basically use the 2nd men Camaro front frame sections. Instead of using the universal mounts, I highly suggest looking into the Holley 2nd gen Camaro swap kits. A friend of mine used them on his 73 Buick and the engine dropped right in.
Andrew
Instagram @projectgattago
Please get in touch for Holley EFI tuning services.
andrewb70 is offline
post #13 of 15 (permalink) Old Apr 7th, 19, 2:16 PM
What happened today to your current small block? What are you looking to gain with this swap?
Steve R is online now
post #14 of 15 (permalink) Old Apr 7th, 19, 3:42 PM
Gary
go with a 6 liter instead of the 5.3. extra cubes will help
gnicholson is offline
post #15 of 15 (permalink) Old Apr 10th, 19, 12:09 PM Thread Starter
Justin
Nothing happened. Honestly I love my small block. I’m just thinking maybe in a few years I’ll do an LS swap, maybe not. I’ll probably put a gear VENDORS on the Muncie first before I do an LS swap.
This Thread is more than 454 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Muncie swap questions sam72 Transmission & Driveline 8 Jun 20th, 14 8:49 PM
NE Georgia Swap Meet, June 7 Brad54 Team Chevelle Cruiz-ins 0 Jun 1st, 14 11:42 PM
NE Georgia Swap Meet, May 10 Brad54 Team Chevelle Cruiz-ins 0 May 3rd, 14 2:31 AM
Keep Pontiac 400 motor or swap for proper 327 65Elco Engine 23 Nov 16th, 13 2:10 PM
NE Georgia Swap Meet, December 1 Brad54 Team Chevelle Cruiz-ins 0 Nov 26th, 12 4:41 PM
