ECM Fuel Pump Control - Chevelle Tech
 8Likes
post #1 of 23 (permalink) Old Mar 8th, 19, 10:50 AM Thread Starter
Geoff
Have a GMPP ls3/4L65e in a 67 ElCamino. Fired the beast up last week, all is well.... Here's the question, does the fuel pump run continuously? Using a Tanks Inc setup with their GPA-4 pump module (225 LPH) and the Corvette style filter/regulator (58psi) Pump is powered by ECM.
Any insight/advice is welcome.
Cheers,
Geoff
BTW, pump sure is noisy, a continuous "whine"
Geoff1200 is offline
post #2 of 23 (permalink) Old Mar 8th, 19, 12:55 PM
Mark
Re: ECM Fuel Pump Control
If the engine is running the fuel pump runs continuously. It also runs for 2 seconds when it primes the system prior to engine start. Do you have any sort of isolation material between your tank and body? If not I suggest adding tank strap insulator strips to help quiet down any whine or noise as almost all electric pumps mounted internally will generate some noise.You need louder exhaust.Ha Ha
modern malibu is offline
post #3 of 23 (permalink) Old Mar 8th, 19, 1:50 PM Thread Starter
Geoff
Good advice, Thanks!
post #4 of 23 (permalink) Old Mar 8th, 19, 2:12 PM
Andrew
Geoff,
The Walbro 255 pump is very loud. Last year I replaced it with a DW200 pump. It is the same flow capacity, but much quieter. Here is a video I made to show the results:
It is dramatic!
Andrew
David Bates, 123pugsy and 1966Chev like this.
Instagram @projectgattago
andrewb70 is offline
post #5 of 23 (permalink) Old Mar 8th, 19, 4:21 PM
I have the same tank setup. As said above the ECM does keep the pump running while the engine is on, key on it primes for 2 seconds, once engine has oil pressure it turns the pump on until you turn the key off.
My first pump was EXTREMELY loud, could hear it over longtubes/turn down exhaust. It started loosing pressure at wot, contacted Tanks Inc, they replaced the pump under warranty. When I pulled the old pump out the anti drain back valve fell out of the feed tube.
Tanks tech support was patient and ran me through a couple of checks beforehand. One thing they said is to make sure the pump isn't making contact with the bottom tank, that would cause noise to be transmitted. The pump is in a sump tank, with sock on bottom, needs to be at least 1/4" off the floor.
Good luck!
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
post #6 of 23 (permalink) Old Mar 8th, 19, 4:43 PM
Great video.
V1rotate is offline
post #7 of 23 (permalink) Old Mar 8th, 19, 7:00 PM
Andrew
Originally Posted by V1rotate View Post
Great video.
Thanks!
Andrew
post #8 of 23 (permalink) Old Mar 8th, 19, 7:04 PM
Andrew
Originally Posted by Hotwire View Post
....key on it primes for 2 seconds, once engine has oil pressure it turns the pump on until you turn the key off.
To clarify, the statement above is not correct. The GMPP harness doesn't have a connector on it for oil pressure. Thus, the ECU does not monitor oil pressure.
When the key is turned to RUN, the fuel pump primes for 5 seconds (maybe 4). If there is no crank signal present, the pump will shut off. Once there is a signal from the crank sensor (RPM) the fuel pump is turned on and will continue to stay on as long as the RPM signal is present.
Andrew
123pugsy and paul bell like this.
post #9 of 23 (permalink) Old Mar 8th, 19, 7:47 PM Thread Starter
Geoff
Gentlemen, I am now Enlightened, Thanks!
post #10 of 23 (permalink) Old Mar 8th, 19, 7:47 PM
What ECM or fuel injection system do you have?
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #11 of 23 (permalink) Old Mar 8th, 19, 7:58 PM
autumngold
Pwm is the best way to go with a pressure sensor.
paul bell likes this.
1970 ls-5 numbers matching
marcrose is offline
post #12 of 23 (permalink) Old Mar 8th, 19, 8:21 PM
Vaporworx offers a PWM fuel pump controller that works off fuel pressure. It greatly reduces the current the fuel pump uses, which reduces fuel heating, and ramps it up as the pressure sensor tells it to.
It also converts your fuel system to returnless.
And Carl at Vaporworx is a hellofa nice guy.
https://www.vaporworx.com/
pannetron likes this.
How may I help you?
1999 Trans Am-500hp
post #13 of 23 (permalink) Old Mar 9th, 19, 9:05 AM
He certainly is!
USAF Retired (1968-1988)
David Bates is offline
post #14 of 23 (permalink) Old Mar 11th, 19, 1:18 AM
Originally Posted by andrewb70 View Post
To clarify, the statement above is not correct. The GMPP harness doesn't have a connector on it for oil pressure. Thus, the ECU does not monitor oil pressure. Andrew
I didn't dig too far into it, but the LSA E-Rod does have an oil pressure connector, and it does not need to be connected for engine operation. However, perhaps if it was hooked up the pressure could be monitored via the OBDII port.
Like many things fun-car related, PWM returnless fuel systems are not for everyone. For me, it was hard to not use the crazy good engineering that the OE's have in today's fuel module. There is nothing in the aftermarket that is in the same orbit.
CarlC is offline
post #15 of 23 (permalink) Old Mar 11th, 19, 6:36 AM
It should be stated that not every electric fuel pump can be powered with PWM power.
How may I help you?
1999 Trans Am-500hp
Fuel pump questions Powellbr Performance 0 Jul 24th, 17 10:28 PM
new mech fuel pump, broken? 1966_L78 Engine 18 Jul 15th, 17 6:56 PM
Fuep Pressure VS Fuel Volume spowers2 Performance 14 Nov 30th, 14 6:09 PM
Ethonal fuel and mech fuel pumps Kevin R Performance 19 May 27th, 13 4:17 PM
Dodge P/U fuel pump failure.. any thoughts? onebad82z Bench Racing 20 Jan 11th, 13 12:27 PM
