ECM Fuel Pump Control - Page 2 - Chevelle Tech
 7Likes
post #16 of 23 (permalink) Old Mar 11th, 19, 8:25 AM Thread Starter
Geoff
Re: ECM Fuel Pump Control
Looking for a quieter pump...
Geoff1200 is offline
post #17 of 23 (permalink) Old Mar 11th, 19, 10:11 AM
I cannot hear my intank pump at all when running, I can barely hear it when key is turned on before starting. I have a plastic tank from a Roadmaster Wagon, and a factory style replacement drop in pump. The differences in that video by Hotwire are impressive, and what I would expect one to sound like in tank. (unless in a metal tank that was near empty, I could understand that being loud echoing around in the metal tank.)
Pioneer4x4 is offline
post #18 of 23 (permalink) Old Mar 11th, 19, 11:15 AM
Originally Posted by andrewb70 View Post
To clarify, the statement above is not correct. The GMPP harness doesn't have a connector on it for oil pressure. Thus, the ECU does not monitor oil pressure.
When the key is turned to RUN, the fuel pump primes for 5 seconds (maybe 4). If there is no crank signal present, the pump will shut off. Once there is a signal from the crank sensor (RPM) the fuel pump is turned on and will continue to stay on as long as the RPM signal is present.
Andrew
Sorry for the misinformation. Back in the day GM used to prime the fuel pump off the ECM (only ECM interaction w/ fuel pump) then had the fuel pump wired into the oil pressure sensor, no oil pressure, no fuel pump, mainly TBI/90's LT1 setups. They then ran the oil pressure sensor to the ECM and used it to kill the engine if no pressure. As of late I guess GM got away from trying to preserve the engine by way of monitoring oil pressure.
I've got an '05 LS ECM, it monitors oil pressure, I datalog it every trip.
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
post #19 of 23 (permalink) Old Mar 11th, 19, 12:26 PM
gary
GM systems used the ECM to turn on the fuel pump relay. It turned on the relay for 2 sec. with key on. If cranking RPM is seen the ECM keeps the relay on. The oil press. Switch also supplies power to the fuel pump independent of the relay. So if the relay was defective it would stop the pump & turn off the engine.
post #20 of 23 (permalink) Old Mar 17th, 19, 7:20 PM
Andrew
DW200, as stated before and shown in my video.
Andrew
Instagram @projectgattago
andrewb70 is offline
post #21 of 23 (permalink) Old Mar 17th, 19, 10:32 PM
I don't think so. My '03 truck's 5.3 had an oil pressure issue. In gear stopped at a light, pressure would drop to zero and I'd hear the rockers clacking. The dash would light up and I'd see a message SHUT ENGINE NO OIL PRESSURE.
But it never shut itself off.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is online now
post #22 of 23 (permalink) Old Apr 30th, 19, 9:40 PM
Russ
Originally Posted by paul bell View Post
Vaporworx offers a PWM fuel pump controller that works off fuel pressure. It greatly reduces the current the fuel pump uses, which reduces fuel heating, and ramps it up as the pressure sensor tells it to.
It also converts your fuel system to returnless.
And Carl at Vaporworx is a hellofa nice guy.
https://www.vaporworx.com/
+1 on the VaporWorx controller and Carl. I'm running a CTS-V pump module in my Rick's tank and you can barely hear it.
pannetron is offline
post #23 of 23 (permalink) Old May 1st, 19, 9:37 AM
gary
My bad, the last sentence should read “so if the relay was defective the oil sw would provide power to the pump & keep the engine running.”
Fuel pump questions Powellbr Performance 0 Jul 24th, 17 9:28 PM
new mech fuel pump, broken? 1966_L78 Engine 18 Jul 15th, 17 5:56 PM
Fuep Pressure VS Fuel Volume spowers2 Performance 14 Nov 30th, 14 5:09 PM
Ethonal fuel and mech fuel pumps Kevin R Performance 19 May 27th, 13 3:17 PM
Dodge P/U fuel pump failure.. any thoughts? onebad82z Bench Racing 20 Jan 11th, 13 11:27 AM
