Fuel Filter Location - Page 2 - Chevelle Tech
post #16 of 18 (permalink) Old Nov 3rd, 18, 7:37 AM Thread Starter
Michael
Originally Posted by rpol78 View Post
Michael, Did you figure anything out on your fuel filter? I just sat the body back on my '67 and may be able to help you out with measurements.
Not yet, the area I mentioned earlier wouldnít work with the filter bracket I purchased. Iím now looking at the body mount cross member that is attached to the body that runs above the rear end. I probably wonít be able to do that until I set the body back on, which may happen in the next couple weeks.
Mikes64 is offline
post #17 of 18 (permalink) Old Nov 3rd, 18, 11:07 AM
autumngold
Re: Fuel Filter Location
Use an in tank pump with a sock.Most new gm vehicles havent used a fuel filter in years.
1970 ls-5 numbers matching
marcrose is offline
post #18 of 18 (permalink) Old Nov 4th, 18, 7:29 AM
I'm looking at changing to the SS fuel lines which route over the arch and am thinking about mounting mine to the inside of the passenger side arch. I currently have the fuel lines with the "square bend" from inline tube and don't particularly like how they run at the back of the car.
67 Chevelle
58 Vette
69 Camaro
Build Thread:
rpol78 is offline
