'64 Elco with turn signal problem/tilt wheel - Chevelle Tech
post #1 of 4 (permalink) Old May 20th, 16, 12:22 AM Thread Starter
Clyde
The right rear turn signal and brake light have stopped working on my '64 El Camino. Bulb is good, ground is good. The truck has a tilt wheel so it has the turn signal switch mounted on the outside of the steering column with cable going up to the turn signal lever. Switch looks to be OK but could have worn or broken contacts. Are there any connectors on the way up from the tail light that could have an open connection? Anybody been through this? Thanks
w7qhhcf is offline
post #2 of 4 (permalink) Old May 20th, 16, 1:31 PM
Re: '64 Elco with turn signal problem/tilt wheel
Do you have a trailer receptacle? Sometimes the splice for the trailer connection corrodes if not sealed properly.
70 El Camino SS 396
68 GTO (Thanks Mom)
06 Silverado
07 SRX
OO52 is offline
post #3 of 4 (permalink) Old May 20th, 16, 7:50 PM Thread Starter
Clyde
Hi Ed, Thanks for commenting. I found the problem, a bad connection in the bulb socket. Now I need to change the tilt wheel turn signal switch. Looks like quite a tough place to get to. Thanks again, Clyde
w7qhhcf is offline
post #4 of 4 (permalink) Old May 20th, 16, 9:29 PM
leo
If it's got buckets, take the driver's seat out, gives a lot more room!!
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
This Thread is more than 1469 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
