Fuel gauge and fuel sending unit issue. - Chevelle Tech
post #1 of 2 (permalink) Old Oct 16th, 15, 9:57 PM Thread Starter
Brand new everything 1972 Chevelle new dash, gauges, wiring, tank, sending you name it its new.
Before final assembly all wiring was tested and the gauge worked great.
Now stays on full with unit unplugged, so when I plug it in it goes to empty.
I tested the sending unit on the OHMs meter and it shows 16 to 18.
I even tested another sending unit I have and still the gas gauge refuses to go to proper reading.
When I test the power from the harness I was using a 12 volt test/light meter and it barely lights up.
Guys how many volts or OHMS should be reading from the power connector of the harness?
I'm lost it worked one time and now FUBAR
Any suggestions
kanadacat is offline
post #2 of 2 (permalink) Old Oct 16th, 15, 10:07 PM
Levon
Re: Fuel gauge and fuel sending unit issue.
Have a read here:
https://www.chevelles.com/techref/ftecref18.html
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is offline
This Thread is more than 1591 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
