Detonation - Chevelle Tech
post #1 of 24 (permalink) Old Sep 21st, 15, 11:47 AM Thread Starter
George
Detonation
I recently had my LS5 454 freshened with semi-high dome pistons and a mild cam. Everything else is stock with the exception of the DUI HEI distributor.
I am having an issue with detonation going up a moderate hill and pouring the coals to it. Running a static 12 degrees of advance with a static and mechanical advance of 32 deg. The Quadrajet was rebuilt by Shawn Murphy in CA. Don't see an issue there. The only other thing that I can think of is that the car runs consistently runs hot. roughly 210-215 degrees. Will the extra heat cause the detonation? Help, I am dumbfounded. Oh! compression ration is supposed to be 9.47 to 1. A very reputable builder did the machine work.
Thanks for any follow through.
George
glinder46 is offline
post #2 of 24 (permalink) Old Sep 21st, 15, 12:31 PM
Re: Detonation
OK, if you can HEAR it, it ain't detonation, it is pinging. Detomnation is mostly 99 -44/100ths percent silent.
That said, how is the vacuum advance set up? Number of degrees, and, let me guess, either blocked off (wrong), or, connected to ported/timed vacuum (also wrong).
Dave Ray is offline
post #3 of 24 (permalink) Old Sep 21st, 15, 12:53 PM
Rob
Re: Detonation
If it really is 9.47 to 1 then it shouldn't be pinging with 12-32 timing unless the quench or something else is way off.
If it's always hot then yes vacuum advance can help that condition. The type of cooling system comes into play as well.
My build thread>
65chevelle300post is offline
post #4 of 24 (permalink) Old Sep 21st, 15, 4:27 PM Thread Starter
George
Re: Detonation
I have done some more research on the problem and have found the following.
Pinging is detonation. Sounds like marbles, however the evidence of detonation usually shows up as white and or metal particles on the spark plug electrode. Seems like I have at least two problems that may be causing the problem. One the spark plugs we used are too hot AC45TS vs AC43TS which they should be. Second the increased water temp can add to the problem. Looks like we need to replace the radiator with at least a high performance 3 core. I thought that I should have known this some 55 years ago but maybe it was a lapse in memory.
Thanks, everyone.
post #5 of 24 (permalink) Old Sep 21st, 15, 4:34 PM
Send a message via MSN to steve_sutherland
Re: Detonation
When you say 32 degrees of mechanical advance, do you mean it is 32 degrees total? or there is an additional 32 degrees advancing beyond the 12 degrees initial? As a ball park you can aim for around 36 degrees total timing (so 24 degrees of advance from your 12 initial). However if you are 12 initial + 32 degrees of advance, that would be 44 degrees total timing which could easily cause detonation.
70 El Camino- Turbo lq9, 78/75 turbo, 3" A2A intercooler, walbro 450, SD 80 lbs injectors- street car.
steve_sutherland is offline
post #6 of 24 (permalink) Old Sep 21st, 15, 7:59 PM
Rob
Re: Detonation
I believe he meant total at 32 degrees, vacuum advance disconnected for 12 degrees initial.
In this case I'd suspect that with "semi high dome pistons" on a 454 that the compression may be higher than 9.47 to 1.
My build thread>
post #7 of 24 (permalink) Old Sep 22nd, 15, 1:41 AM
Re: Detonation
OK, well, you already know all the answers, don't need any help, then. Why'd you ask for help.
Dave Ray is offline
post #8 of 24 (permalink) Old Sep 22nd, 15, 12:19 PM Thread Starter
George
Re: Detonation
12 degrees of initial and 20 degrees of mechanical advance. Total of 32 degrees.
post #9 of 24 (permalink) Old Sep 22nd, 15, 12:21 PM Thread Starter
George
Re: Detonation
If I knew everything I'd be President. There are always things that you might miss and can only find those out thru collective answers.
post #10 of 24 (permalink) Old Sep 22nd, 15, 5:57 PM
Re: Detonation
Hi George,
I use a 160* thermostat in my combo.
I am willing to bet your vacuum advance is putting out too much timing at part throttle.
I would try running it with it disconnected temporarily to see if your pinging/detonation issue goes away.
If it does then following Dave's recommendations on tuning the v/a will be very helpful.
mr 4 speed is offline
post #11 of 24 (permalink) Old Sep 22nd, 15, 7:59 PM
Richard
Re: Detonation
George
Hello George, just a couple of thoughts to try to help.
Your first sentence, domed pistons and a mild cam, could set the stage for a detonation problem. The Dynamic Compression Ratio of the motor could be high enough to exceed the anti-detonation qualities of the fuel you're using. The generally-accepted limit for pump gas is 8.50:1 DCR with iron heads and about 9.0:1 DCR with aluminum heads. Equating this to cylinder pressure, Crane Cams engineers have stated that a figure of about 165 psi would be the limit for pump gas. They make no concessions for aluminum heads or a tight squish.
Here's an article that I wrote for another forum that may help you understand.
http://www.crankshaftcoalition.com/w..._compatibility
First thing I would do is to perform a compression test of the motor.
1. Warm the motor to operating temperature.
2. Remove all spark plugs to prevent unnecessary laboring of the starter.
3. Disable the ignition system at the coil to prevent a fire.
4. Use wire or rope/string to hold the primary throttle blades wide open so the motor can breathe.
5. Allow each cylinder to make at least 5 "chuffs" to that the compression gauge will register the max pressure of the cylinder.
Write 'em down as you go. If the compression exceeds 165PSI, then either retard the cam that's in there now or change to another cam that closes the intake valve a little later and re-test.
If cranking pressure is under 165 psi, then the static compression ratio and cam timing are OK with each other for operation on pump gas and we will have to look elsewhere for the problem.
My next stop would be to verify the harmonic damper for showing the correct TDC mark. If that mark is incorrect, then everything else that depends on that mark will be incorrect. Here's an article I wrote that may help you....
http://www.crankshaftcoalition.com/w...op_dead_center
There is another possibility, excessive squish/quench. Most builders will suggest the anti-detonation qualities of a 0.035" to 0.045" squish. This figure is set when the planning of the motor takes place, not as an afterthought. If everything else is marginal and the squish is too wide, then detonation is assured.
As far as the operating temperature, it may be contributing to the detonation, but it is not the main cause. Millions of autos and trucks are out there operating with temperatures exceeding what you are seeing with your motor. Ideally, in my opinion, a rodder should engineer the package to run at about 195/200. These temps will help to vaporize acids that collect in the motor oil as a result of the internal combustion process. The auto makers pay one heck of a lot of money to hire engineers who will spec out all the parts for a motor to operate at max efficiency for a long time. So, I have to ask you, when's the last time you saw an original equipment motor from the factory that used a 160 thermostat??????????
All of the fellows reading this should make themselves familiar with reading spark plugs. It should be the first "go-to" when you are either chasing a problem or you just want to know that the motor is maximized for the task at hand. In order to read plugs properly, you need to make a max power run, then chop the ignition, go to neutral and coast to a stop, where you will pull the plugs and read them. Idling back to the pits or around the corner to your house will re-color the plugs to indicate the tuning at less than full throttle and will be worthless information to you.
The first indicator of detonation will be seen up on the porcelain of the plug, where it will require a 10X loupe to see what's going on. When detonation first begins, the sledgehammer strike on the piston crown jams the piston down in the bore and squirts engine oil from the top ring all across the chamber. The only place you will see this is on the porcelain of the spark plugs. As things get worse, the black oily specks that you first see will be replaced by silver specks. These are little pieces of the piston crown......the piston is melting. Get yourself a plug loupe like this.....
http://www.jegs.com/i/Longacre+Racin...XsgRoCIxzw_wcB
https://www.google.com/webhp?sourcei...0spark%20plugs
For the rest of you fellows, it should be evident that it is vitally important to know the exact static compression ratio of the motor so you can match up other components. Finding SCR requires 5 values....
1. cylinder volume in cc's
2. combustion chamber volume in cc's
3. head gasket volume in cc's
4. piston deck height volume in cc's
5. piston crown volume in cc's
I will be most pleased to help any of you fellows to determine the exact static compression ratio of your build, with dished pistons, flat-tops or pop-ups. All you have to do is ask and provide me with the 5 values.
Richard
techinspector1 is offline
post #12 of 24 (permalink) Old Sep 22nd, 15, 8:20 PM
Re: Detonation
FWIW,I run 10.4 to 1 compression with a 233/[email protected] 110 LSA cam,200 lbs. cylinder pressure and runs on 93 octane just fine with 36* of total timing.
This is small dome (.100 tall) 101 cc heads. Operating temps are 180-185*
post #13 of 24 (permalink) Old Sep 22nd, 15, 8:34 PM
Richard
Re: Detonation
I'm guessing you built a tight squish into the motor and used aluminum heads.
Richard
post #14 of 24 (permalink) Old Sep 22nd, 15, 8:36 PM
Re: Detonation
Originally Posted by techinspector1 View Post
I'm guessing you built a tight squish into the motor.
piston is .007 down in the bore.
post #15 of 24 (permalink) Old Sep 22nd, 15, 8:38 PM
Richard
Re: Detonation
Yep, 0.007" piston deck height and a 0.039" composition gasket makes a 0.046" squish, no doubt very close to optimal with the heavier rotating assembly over a small block. Considering crank flex, rod stretch and piston stretch at top dead center, you are likely very close to a piston/head kiss. WELL DONE.
Richard
This Thread is more than 1605 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
