Gas pedal throttle accelerator linkage assembly - Chevelle Tech
post #1 of 7 (permalink) Old Sep 7th, 15, 6:51 PM Thread Starter
Blake
I broke this while lowering my engine, the thing got caught onto the engine and broke off.
Does anyone know where I can find this? I looked everywhere and I'm only finding things made before and after this.
The pivot itself is fine, its just the cast iron rod that needs to be replaced. I could try welding the little piece back on, however it wouldn't fun to have it come loose again.
I found this on ebay: http://www.ebay.com/itm/Camaro-Nova-...d88aba&vxp=mtr
It's for a Camaro. The only problem is that the throttle bar pivot support thing will not fit on my firewall... and the throttle bar is longer than the one I have right at the pedal part. To make this work I would have to use my old bar pivot support and cut pedal part of the bar shorter, and then join my old one. The part that goes through the firewall measures 4 inches, like mine. All that work and I could just make my own, but then I have to worry about specific angles, and bends. I just don't see why I can't find anything for my year. It makes no sense.
It's for a 1966 Chevelle that used to have an inline 6, but has a v8 now.
blackbird307 is offline
post #2 of 7 (permalink) Old Sep 7th, 15, 8:09 PM
sam
Re: Gas pedal throttle accelerator linkage assembly
When I broke mine on my 67, I went cable, and ordered lokar pedal and cable. Pedal bolts to same holes as original linkage.
1967 Royal Plum, 434BB, AFR Heads, 3.90 gears, New Chris Straub Hyd Roller!, 200r4
scalise71 is offline
post #3 of 7 (permalink) Old Sep 7th, 15, 8:14 PM Thread Starter
Blake
I was looking at the gas pedal assemblies etc after 66, and it seems they have gotten longer.
I may be able to fix it by getting some rod, cutting it just over 4 inches length and then cut the broken part off and weld the new length on. After I grind part of it away to create that half circle shake. I think I may try that first.
post #4 of 7 (permalink) Old Sep 8th, 15, 6:58 PM
Rob
Nobody sells these new but I found one on ebay for 30 bucks. Looks old and rusted but you only need the shaft that slides through. The Lokar version is way more expensive and not original.
Ain't no way you are making that part from scratch to look or perform anything like the original.
Used original version for 30 bucks at the top of the page> http://www.ebay.com/itm/Used-Origina...item43e235ba83
My build thread>
65chevelle300post is offline
post #5 of 7 (permalink) Old Sep 18th, 15, 1:20 AM Thread Starter
Blake
Unfortunately I lost the bid war. But I managed to fix my old throttle rod by cutting off the remainder of the 4 inches up to the stop. I got a 3/8 in rod and welded it onto the throttle lever. I then added a 3/8 inch washer to it and welded that. I shortened it to exactly 4 inches (from washer to end of key) by cutting off the remainder. After I grinded away some metal in order to make the groove for the level itself. I physically tested the welds after grinding away the slack, and proved to be durable. For the original application, it works great!
post #6 of 7 (permalink) Old Sep 18th, 15, 3:35 PM
Rob
Good idea there just welding on the rod rather than trying to make the entire part from scratch which would have been a real pain.
Winning the bid would have been easier but I like the idea of fixing the original parts when ever possible. Nice work.
For the rod that goes to the carburetor, I used the original rod, had it chromed then used a die and threaded the end at 1/4" 28-TPI then installed a Heim joint with ball end female threaded from McMaster Carr. http://www.mcmaster.com/#standard-rod-ends/=yztmru
My build thread>
post #7 of 7 (permalink) Old Sep 18th, 15, 3:50 PM
Looks like you did a great job on it.
This Thread is more than 1619 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
