70 Chevelle Cowl Induction Hood - Page 2 - Chevelle Tech
post #16 of 25 (permalink) Old Aug 24th, 15, 8:02 PM
Chainsaw936
Re: 70 Chevelle Cowl Induction Hood
Originally Posted by jjr158 View Post
The video appears to be an automatic Chevelle. When the Chevelle enters the freeway ramp I see that the flapper door does open. However, it appears as though the flapper door opens at approximately 3000 rpm's give or take a few rpm's and not passing any cars suggesting that the throttle was not WOT. My flapper door only opens in forth gear at or near WOT. I have a few more things to check before I throw in the towel.
I put the smaller vacuum line on this weekend with almost no change. If anything it's even less responsive in 4th than before. I've checked everything except the pod diaphragm but with suction on the hose, it closed and stayed there until i removed my finger. Last thing is shimming the outer flapper to get it level. Has anyone used the shim kit from opgi? I'm assuming that is what the kit is for.
Sent from my SAMSUNG-SM-G920A using Tapatalk
chainsaw936 is offline
post #17 of 25 (permalink) Old Aug 25th, 15, 8:00 AM
robert
Send a message via AIM to monte7ocar Send a message via Yahoo to monte7ocar
JJR that's from my 70 Monte that has a Chevelle cowl induction hood on it. During that video we were only running 65mph right around 1900 RPM's. The part where the door opens was due to a timing issue. I've never been in a 4 speed Chevelle only in a turbo 400 and when getting on the throttle the outside door would open.
monte7ocar is offline
post #18 of 25 (permalink) Old Aug 25th, 15, 8:44 PM Thread Starter
Jay
Thanks for the information. With my Chevelle It only opens in 4th gear and I have to have the accelerator to the floor at WOT to get the flapper door to open.
jjr158 is offline
post #19 of 25 (permalink) Old Aug 26th, 15, 11:40 PM
Chainsaw936
Originally Posted by mr 4 speed View Post
Make sure you have full throttle actuation, meaning when the gas pedal is to the floor it also fully open at the carb.
In my quest to get the cowl working, I checked the primaries on carb per mr 4 speeds suggestion. Warmed up motor to 180 to make sure the choke was not causing them to stay closed under WOT. Had the wife press the gas all the way to the floor and nothing? Primaries didn't move. The car has felt slow for a BBC and i'm guessing this is a big reason. They aren't hanging up and move pretty easy when I manually move the butterflies. I'm a noob and don't have the experience on how to fix it so it's going in for a tuneup. Let you know if this has an effect on the cowl flapper working better.
post #20 of 25 (permalink) Old Sep 23rd, 15, 6:11 PM
and.....................
Marc S
71 SS 454 ELCO
Edelbrock Proflo4
TKO600
Strange 12bolt w/4.10
1971ss454Elco is online now
post #21 of 25 (permalink) Old Sep 23rd, 15, 7:27 PM
Darren
LACK of vacuum is what makes them open. When the car is off the flapper is open, with it on itís closed. Itís working, just not as quickly as you want.
I find it incredibly hard to believe your wife floored the car and it the primaries did nothing. Iím almost certain you are not looking at the correct part(s). That being said, even running crappy will have extremely little effect on the flapper. Higher RPMís has nothing to do with it either, LOAD does. At a standstill (as you said) there is NO load. Replace the pod and remove the stupid slow control valve and be happy.
Mine with a 4-speed
It's painted now...
If you donít push the limits how are you going to find the weak spots?
USMC- Retired
My car: 1970 Chevelle
Factory 12 bolt /4-Speed Malibu -Dual stage wet nitrous with heater & purge - Holley Strip Dominator, Speed Demon 750 CFM - (All MSD distributor, blaster 3 coil, 6AL, & 3 stage retard) - 4 wheel disk brakes - Aeromotive Fuel system Ė Boss 338 18ís - BMW 5.25 true HID projector mod - and of course... the FLAPPER - bla, bla, bla.. lots of other expensive stuff I canít remember
70 nialator is offline
post #22 of 25 (permalink) Old Sep 23rd, 15, 7:45 PM
Darren
Same car, same day... LOOK CLOSE. All the RPM and power in the world and as SOON as the tires break loose IT CLOSES Because the load is gone.
USMC- Retired
post #23 of 25 (permalink) Old Sep 24th, 15, 12:32 PM
you need to loosen the nut that holds the throttle bracket on the carb and gently push the bracket towards the firewall.
mr 4 speed is offline
post #24 of 25 (permalink) Old Sep 24th, 15, 8:34 PM
http://www.youtube.com/watch?v=SWcb1ZtgjeQ
It still shouldn't close! Mine has never closed because of loss of traction.
*Full disclosure I do not run the little plastic vacuum control valve in line with the canister so maybe that has something to do with it.
1fast71elco is offline
post #25 of 25 (permalink) Old Sep 24th, 15, 9:12 PM
George
I'll have to shoot vid of my 70 Elky
the few times it has idled far down it wobbles....stall warning!
I have automatic, at WOT, it opens and stays open
George Kettler
o 68 Vette 427/M-20/3.36 28 year owner
o 68 Camaro Vert 327 project, painted, assembly stage
kettbo is offline
This Thread is more than 1607 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
