Popping noise need help!!!! - Chevelle Tech
post #1 of 9 (permalink) Old Apr 9th, 15, 6:14 PM Thread Starter
Lamar
Hey guys,
Got a 71 chevelle. 350 c.i. Th350. Starts fine runs fine but when I get between the speeds of 55-70 I hear a popping sound under the good. I did install new distributor (summit racing HEI) and spark plugs (Accel spark plugs). Doesn't knock or do the popping sounding until I reach that speed range. Any ideas??? I'm lost.
Lmrmiller is offline
post #2 of 9 (permalink) Old Apr 9th, 15, 6:25 PM
RonO.
Re: Popping noise need help!!!!
Carb may be running lean at higher speeds, could very easily be a minor adjustment to remedy. If your not sure how to do this you can always go to a shop and have them adjust carb as they increase rpm's. (AFR, air to fuel ratio) is probably weak, needs more juice. Did you put a timing light on it after Dist. install?
70SSTHUMPER is offline
post #3 of 9 (permalink) Old Apr 9th, 15, 7:11 PM Thread Starter
Lamar
My HB didn't have the timing marks on. You think I should start over. Get the TDC mark the HB and go from there? And also I have as Holley 750 4 barrel. And only the front float had gas in it. Is that a problem too?
post #4 of 9 (permalink) Old Apr 9th, 15, 7:41 PM
Darren
I have never seen a harmonic balancer with no markings on itÖ I think you should get a wire wheel that fits into a cordless drill and do a little cleaning on it. What would be the point of a part that is useless, Iím sure they are there you may just have to dig for themÖ
EDIT - Obviously timing is a critical part of your overall tune, and it MUST be done.
If you donít push the limits how are you going to find the weak spots?
USMC- Retired
My car: 1970 Chevelle
Factory 12 bolt /4-Speed Malibu -Dual stage wet nitrous with heater & purge - Holley Strip Dominator, Speed Demon 750 CFM - (All MSD distributor, blaster 3 coil, 6AL, & 3 stage retard) - 4 wheel disk brakes - Aeromotive Fuel system Ė Boss 338 18ís - BMW 5.25 true HID projector mod - and of course... the FLAPPER - bla, bla, bla.. lots of other expensive stuff I canít remember
70 nialator is offline
post #5 of 9 (permalink) Old Apr 9th, 15, 8:55 PM Thread Starter
Lamar
Good to go. Thanks
post #6 of 9 (permalink) Old Apr 9th, 15, 8:58 PM
Charlie
Yes, the rear bowl must have fuel. How did you determine that fact? Through the brass plug in the bowl, or did you remove the rear bowl?
Charlie
1970 Chevelle Malibu/SS Tribute
Cortez Silver, 355 SBC, 200 4r
1967 Camaro RS (basketcase project)
1984 F-150 parts hauler
2011 Chevy Malibu LTZ Granite Black daily driver
vetteman_72 is offline
post #7 of 9 (permalink) Old Apr 9th, 15, 9:19 PM
G.B.
Hope it is not...... but a wiped cam will pop through the carb...if the exhaust lope is wiped it will force the exhaust out the intake...carb..
GB
72wcode is offline
post #8 of 9 (permalink) Old Apr 9th, 15, 9:42 PM Thread Starter
Lamar
The bowl. I'm a novice at this. I noticed the gas trickle through the front 2 Venturi. But not the back 2. I had a mechanic " tune my carb" that's when the knock occurred.
post #9 of 9 (permalink) Old Apr 9th, 15, 9:45 PM Thread Starter
Lamar
And I checked the float levels the front bowl was good. But the back bowl was empty. Any ideas?
This Thread is more than 1701 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
