#1 Wire Not Sending Spark at idle - Page 2 - Chevelle Tech
post #16 of 22 (permalink) Old Nov 23rd, 13, 3:19 AM
Nick
Re: #1 Wire Not Sending Spark at idle
Originally Posted by Schurkey View Post
If it has too-LOW resistance--specifically, if it provides a reasonable path to ground, the coil will never build voltage because the current will just bleed off.
The plug has to have an open-circuit (specifically, a gap) that current can't bridge until the voltage is high enough to ionize.
Wide gapped plug = high resistance
nsnarsk is offline
post #17 of 22 (permalink) Old Nov 23rd, 13, 10:13 AM
Take wire AND plug from #3 and put them on the #1 rotor cap tower to cylinder. If triggers the light look no further
PA Camaro Guy is offline
post #18 of 22 (permalink) Old Nov 23rd, 13, 11:43 AM
Any-gapped plug = high resistance until gap is ionized by voltage. Larger gap requires higher voltage to ionize.
But the point is, it doesn't matter what the gap is if the porcelain is covered in material that conducts electricity, so the current drains down the conductible coating instead of jumping the ionized gap. That's a fouled plug.
Schurkey is offline
post #19 of 22 (permalink) Old Nov 24th, 13, 6:53 PM Thread Starter
alright everyone - so the final results are in
#1 not firing -
diagnosed down to ignition issue
replaced cap + rotor = no fix
swapped wires around = no fix
propane torch on the plug + good cleaning = fixed - had only (2) slight mis-fires on a (30) minute hard test drive up hills with rpms up to 5k - but I think due to wire being a little loose - pulled in and heard a ticking - checked and found wire fell off - re-snugged wire - back on road no mis-fires
Thank you guys - really appreciate everyone's help
Dave - do you recommend I know put in a new plug and save the old one for beating up ?
InkedBrain is offline
post #20 of 22 (permalink) Old Nov 24th, 13, 7:37 PM
Randy
You just proved Schurkey's explanation, he was dead on. Probably a good idea to replace all plugs.
Randy
TC # 5401
67 Project SS Clone
pnugene is offline
post #21 of 22 (permalink) Old Nov 24th, 13, 7:59 PM
Gary
i assumed when you replaced the secondary ignition for #1 on cyl 1 you replaced the plug too. i thought it actually wasnt firing on cyl #1.thats my fault.what light do you have.even with the firing voltage reduced a bunch my snap on light and others i've used will trigger with the wire grounded
gnicholson is offline
post #22 of 22 (permalink) Old Nov 25th, 13, 8:40 PM Thread Starter
a cheapo sunpro - I snagged from my buddy - he wouldnt let go of the snap-on ones - fricken snap on hoarders - holds on to them harder then his women
This Thread is more than 2316 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
