Screwy fuel issues..... - Chevelle Tech
post #1 of 6 (permalink) Old Jun 28th, 09, 8:40 PM Thread Starter
I have a 70 chev Monte, 350 with a 4MV q-jet. It started cutting out at first, after a week it would hardly run at all. It will run good when first started, and after a minute it will start acting as if it is chocking out! Real rough idle.. then it dies. Wont start for a few mins, then will,,, but runs really rough. I rebuilt the carb (origional) Same issue. Replaced fuel pump, same issue.......
Any ideas?? I have a feeling the carb is just truely a goner....
Please let me know your ideas.
70 Monte guy is offline
post #2 of 6 (permalink) Old Jun 28th, 09, 11:51 PM
Verle
Re: Screwy fuel issues.....
Before you spend a lot of money on a carburetor, check the ignition system.
Verle
Tulsa, Ok
Verle is offline
post #3 of 6 (permalink) Old Jun 28th, 09, 11:54 PM Thread Starter
I have checked the points, rotor and cap. Wires and have replaced the coil, Anything I might have over looked?
post #4 of 6 (permalink) Old Jun 29th, 09, 8:53 AM
Verle
If you have points there are condensers on the points and on the coil.
Replace them.
Keep the coil condenser if it is the original, and it may be as most people never replace them. Very hard to find the correct original part number.
Verle
Tulsa, Ok
Verle is offline
post #5 of 6 (permalink) Old Jun 29th, 09, 10:17 AM
checked your fuel filter and sock filter in tank?
billntenn1972 is offline
post #6 of 6 (permalink) Old Jun 30th, 09, 10:02 PM
Chevelle Doctor
Also check the rubber hoses at the connection between the fuel tank and the lines to the front of the car.
Authentication and pre-purchase inspection service still available. PM me for more information.
Still looking for that elusive 76 Nova SS.
People who have nothing better to do than b!tch about signatures need to get a life.
70 Chevelle L78/M21
10 Avalanche LT 1500 4wd
06 Equinox
Dave Birdwell is offline
This Thread is more than 3890 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
