Won't idle well - Chevelle Tech
post #1 of 3 (permalink) Old Jun 14th, 09, 12:14 AM Thread Starter
Won't idle well
My 71 has a 307 2bb, and it starts fine, and idles fast (cold idle).
However, the idle won't slow down. If I step on the gas when it's idling fast, it will idle down but then stall out. If I shift into gear (automatic) when the car is idling fast, it stalls out.
Any thoughts greatly appreciated!
danwiththe71 is offline
post #2 of 3 (permalink) Old Jun 15th, 09, 5:51 AM
Nabor(Neighbor)
Re: Won't idle well
have you recently ran it empty? check fuel filter(s?)
MADNUTZ is offline
post #3 of 3 (permalink) Old Jun 16th, 09, 1:28 AM
gus
Re: Won't idle well
sounds like it could be a vacuum leak. take a big towel and smother the carb while it's running. if it doesn't die out, odds are you have a vacuum leak.
70 ss 396 4 spd.
mrfuzzy is offline
This Thread is more than 3905 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
