How loud should an electric fuel pump be?? - Page 2 - Chevelle Tech
post #16 of 20 (permalink) Old May 28th, 09, 12:04 AM Thread Starter
Re: How loud should an electric fuel pump be??
I ordered one of the Edelbrock Quiet Flow pumps. The shop I bought it from said they are much quieter than the Holley ones (Edelbrock says 4 - 14 db quieter). Once I get it installed, I will let you know if it made a difference.
My Chevelle w/ open headers:
WakkoWarner is offline
post #17 of 20 (permalink) Old May 28th, 09, 12:42 AM
Jason
I run a holley blue without a return style reg... I had a really bad vibration from it pretty annoying, mine was mounted on a piece of angle iron off the bottom of the trunk ... I made a isolator set up by sandwhiching the angle iron with some shock asorber bushings I cut in half on either side of the angle iron . works great cut vibration 50% I'd say . Much more live able now
smokn72ss is offline
post #18 of 20 (permalink) Old Jun 2nd, 09, 4:02 PM Thread Starter
I just switched the pump out for one of the Edelbrock 1791 Quiet Flow pumps. The reduction in sound is noticeable. I can hear the pump run, but not while I am driving (the Wysco pump could be heard no matter what). I will eventually have to relocate the pump, as its current mounting location makes it hang down a little too far (the base on the Edelbrock unit is different from the Wysco/Holley units, so it necessitated a little manipulation to get it in). But, being self regulated at 6.5 psi is great & the reduced noise is even better. I think these run just a little bit more than the Holley pumps, but the few extra dollars is worth it.
post #19 of 20 (permalink) Old Jun 27th, 09, 7:02 AM
Paul
I have a carter street & strip pump and only notice it before i start the engine.I mounted mine right infront of the gas tank. I made a bracket and weldid it to the trunk floor. Not sure but having it in the middle might be helping.
Paul
454/T400/9" in a 67 Beaumont
Paul-ish is offline
post #20 of 20 (permalink) Old Jun 27th, 09, 8:01 AM
Vince
I'm running this new Holley 125gph pump, 6.5-7psi internal reg. Cant hear it when motor is running, and I have pretty quiet muffs. I'm pretty happy so far.
*2011 Mustang GT premium
*61" Scag Kohler 22hp 7mph
69-CHVL is online now
This Thread is more than 3923 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
