How to seal an intake? - Chevelle Tech
post #1 of 11 (permalink) Old Dec 31st, 04, 8:42 PM Thread Starter
Post
I have taken off my aluminum intake to try and fix a leak near the distributor. I have had people tell me to use the cork gaskets and some tell me not too. What is your guys opinion on the best way to reinstall an aluminum intake onto aluminum heads to keep it from leaking. (especially near the distributor)
Perry
1966 Malibu
355, 4 speed with 3.73 gear
Best 1/4 mile e.t. 13.74
Best 1/4 mile MPH 100.68
oregonchevelle is offline
post #2 of 11 (permalink) Old Dec 31st, 04, 9:58 PM
Post
First, GET EVERTHING CLEAN AND DRY. Use brake cleaner to completely degrease the top end. Then use "printo seal" gaskets. Throw away the end seals. Use Hi Tack around the water ports and lay the sides (there is a "correct side up" marker on them. Lay a bead of Black Silicone (I use 598B black) 1/4" or so across both ends and extend it up onto the side gaskets at the corners. Let the silicone sit for about 15 minutes, then drop the manifold straight down onto the engine then install all bolts using a sealer on the threads. You should also use SAE washers on all the bolts to get a proper torque. Torque starting at the center and circle your way out to the ends. Let it sit for 18 to 24 hours before you add water or try to start. After starting and warming engine, recheck torque on all bolts. You will have NO leaks, well at least on the intake. Don't forget to install the new Distributor gasket.
Dave Bradley
d1_bradley is offline
post #3 of 11 (permalink) Old Jan 1st, 05, 1:26 AM
Post
I have always had good luck with Fel-Pro's rubber end seals, with an added dab of silicone at the ends. But doing it like Dave described will result in a custom made silicone seal that fits your engine and intake perfectly, and pretty much never leaks. Only reason I don't do it like that is that I'm such a worry-wart, and would rather risk a small oil leak, rather than a big blob of silicone falling down in my engine if I screw up when mounting the intake. I know that chances of that happening are slim to none if you just let it dry, but still... [img]smile.gif[/img]
1969 Malibu in progress
Olle is offline
post #4 of 11 (permalink) Old Jan 1st, 05, 6:03 PM
Rob
Post
Looking at my the ends of my ZZ4 intake it looks like GM has laid a bead of silcone down.
598 Ultra Black by Loctite "guaranteed not to leak". It is a true OEM hi-temp silcone, meets GM Spec. Much better than the gold/copper silcone
I use this on my coppergaskets for my headers. They have never leaked.
Brob is offline
post #5 of 11 (permalink) Old Jan 2nd, 05, 8:10 PM
Gerry
Post
Just a bead of black silicone has always woked for me.
Gerry....
1970 Black Cherry SS396
1970SS396&1967 is offline
post #6 of 11 (permalink) Old Jan 3rd, 05, 10:37 AM
Post
when I put my afr heads on I had a problem sealing the back of the intake. I always have just used rtv on the ends but this one had a pretty big gap and on the third attempt to seal it I ended up using a bead of rtv, then the cork end gasket, then another bead of rtv on top and that finaly sealed it. Also I found out from afr
that they make spacers for the ends if you have a large gap on the ends.
which was going to be my next step but I didn't need them after I did the rtv,cork,rtv sandwich
turbo is offline
post #7 of 11 (permalink) Old Jan 4th, 05, 3:50 AM
Richy Rich
Send a message via AIM to Hi-po SS 454
Post
Follow d1_bradley's instructions, except I use a high temp. aluminum color silicone sealer which matches the color of an aluminum manifold, for got the name of it, but it works for me.
Rich
71 SS MJ 468" 570 HP 608 Torque Hyd Roller M22W (autogear) Muncie 4 sp 12B 3.55 posi...
76 TA SOLD
01 HD Deuce
Walk around vid:
Hi-po SS 454 is offline
post #8 of 11 (permalink) Old Jan 6th, 05, 1:34 PM
Post
follow what the others have said, but i have gone 1 step further and turned the intake over, and roughed up the seal area(100 grit) on the ends to give the sealer something to grip on-i have had the oil slip between the sealer and manifold in some rare cases
when your credit cards are maxed, have the limits raised
forcd ind is offline
post #9 of 11 (permalink) Old Jan 6th, 05, 6:16 PM
Keith
Post
PST by Loctite is a very good thread sealant. Judging by the number of broken intakes and carb bases that I have seen, it is a good idea to use a torque wrench and do everything to spec. This will pretty well guarantee no broken parts.
Keith Tedford is offline
post #10 of 11 (permalink) Old Jan 7th, 05, 2:47 AM Thread Starter
Post
Thanks for the help guys. I ended up putting the black 598 silicone on the ends up onto the ends of the gaskets too. Seems to be working but will not be able to tell for sure until I can take it out and drive it some. Redoing the front end so will be a few more days. Just let it idle for 5 min. or so so far.
Perry
1966 Malibu
post #11 of 11 (permalink) Old Jan 7th, 05, 7:22 PM
Jeremy
Post
Looks like its gonna rain from now till June, you already missed your chance!
Jeremy
factory 4-sp, rally gauges, hidden headlights
1970 K-20
1962 Pontiac Catalina Convertible
webfoot is offline
This Thread is more than 5525 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
