Ignition rod popped out - Chevelle Tech
post #1 of 8 (permalink) Old Dec 14th, 04, 4:52 PM Thread Starter
Post
The rod that turns the car on in the steering column popped out. Is there an easy trick to fix this or am I going to have to take apart the steering column. Thanks
Mike Smith
72 Chevelle, LS 6.0 LQ9 4l80e
smitty454 is offline
post #2 of 8 (permalink) Old Dec 14th, 04, 9:24 PM
Captain Morgan
Post
if this popped out at the bottom end you just need to unbolt the switch and reassemble it
if it popped out at the top I'm pretty sure it has to come apart
Cars and Guitars
Tom's 68 is offline
post #3 of 8 (permalink) Old Dec 15th, 04, 1:30 AM Thread Starter
Post
Yeah its undone at the top so im outta luck. thanks
Mike Smith
post #4 of 8 (permalink) Old Dec 15th, 04, 8:48 AM
Post
It makes a difference if it is a tilt or a standard (non-adjustable) column.
Can you post what type?
JIML82 is offline
post #5 of 8 (permalink) Old Dec 15th, 04, 12:30 PM
Post
First of all, I have a lot of information on Corvette steering systems of the same vintage as your Chevelle. Saginaw Steering Gear made all the steering columns for GM in that era. Saginaw did a great job of standardizing components. A Corvette tilt and telescoping column is just a glorified tilt column. Standard (non-adjustable) columns had a lot of common parts. So a lot of Corvette parts probably fit a Chevelle.
Here is my best analysis of your problem. When you rotate your ignition key, you rotate a small plastic gear inside the steering column head. That small gear engages a small die cast rack. That rack slides up and down pushing and pulling on the rod that actuates your ignition switch.
I think that your rod is disengaged from the rack because the die cast rack probably broke. The bad news is that you will have to tear your column apart in order to get at the rack and take a look at it. There are complete instructions on disassembling your steering column posted at
www.corvettefaq.com/A-car.asp
Download all of the instructions (either the Std Column or the Tilt Column). You will need all of the instructions under the appropriate type steering column. They will assist your in pulling the column out of the car for a teardown.
Standard (non-adjustable) columns are very different from tilt columns. So here are two approaches depending upon your type of column.
If you have a standard (non-adjustable) column and you determine that the rack is broken:
I don't have any Chevelle supplier brochures so I can only give you some ideas on Corvette parts that might work. Hopefully, you have some sources for equivalent Chevelle parts.
There is a Corvette supplier by the name of Dr.Rebuild. He has a ton of old parts. Just don't **** him off. He won't sell to you if he doesn't like you. (Again, assuming that the rack is broken). Looking at his websight I find that there is a rack & rod assembly for standard Corvette steering columns:
rod & rack 2187440
The problem is that there were different length rods depending upon the GM car lines. I don't know if the Corvette rod & rack is the same length as the Chevelle or not. (I am equally sure that Dr.Rebuild won't know either). If you have a standard column there should be an equivalent Chevelle rod & rack assembly. Hopefully a Chevelle supplier can get you the correct part. Otherwise, you might have to take a stab at the Corvette part. Or find a junk Chevelle standard column and tear it apart.
If you have a tilt column and you determine that the rack is broken.
The Corvette T&T rack is available from Dr.Rebuild
Ignition Switch Actuator (toothed rack only) 2187426
This rack I am pretty confident will work in a Chevelle tilt column.
Tilt columns had a actuator rod with a small casting with a pin on it to engage the rack. If the problem is that part, you will have to find a Chevelle tilt column part to fix it because I just don't know if the equivalent Corvette part is the correct length.
Continue posting on your problem and I will see what I can do to help.
Good luck
JIML82 is offline
post #6 of 8 (permalink) Old Dec 15th, 04, 9:50 PM Thread Starter
Post
Thanks.
Mike Smith
post #7 of 8 (permalink) Old Dec 15th, 04, 9:55 PM Thread Starter
Post
Yeah its a tilt column I know it originally came with a non tilt and im not sure what kind of car it came out of. And im 16 and I dont really know if I can tackle this job.
Mike Smith
post #8 of 8 (permalink) Old Dec 16th, 04, 12:16 AM
Post
Now that I know that you have a tilt column I would bet that you have a broken rack. The following download is a blowup of your steering column. The part that I think is broken is #37. http://www.corvettefaq.com/acar/TiltColumnBlowup.doc
You can download this paper to help remove the column from your car:
http://www.corvettefaq.com/acar/Tilt...D&R226JA04.doc
You will need these additional download papers in order to disassemble your tilt column:
http://www.corvettefaq.com/acar/Tilt...D&R316JL03.doc
http://www.corvettefaq.com/acar/TiltColumnLineDrwg2.doc
http://www.corvettefaq.com/acar/TiltColumnLineDrwg3.doc
I know this seems awfully intimidating but the above papers will really step you through the whole process. And don't forget, help is only a post away.
JIML82 is offline
This Thread is more than 5552 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
