Busted off oil dip stick! How to fix? - Chevelle Tech
post #1 of 6 (permalink) Old Oct 31st, 04, 5:04 PM Thread Starter
Post
I broke off my oil dip stick at the block. How do I get the rest of it out? can't seem to reach it.
Perry
1966 Malibu
355, 4 speed with 3.73 gear
Best 1/4 mile e.t. 13.74
Best 1/4 mile MPH 100.68
oregonchevelle is offline
post #2 of 6 (permalink) Old Oct 31st, 04, 6:26 PM
Send a message via AIM to onick
Post
you can make something to "hook" the rest of it out of the block? try to fit a slide hammer in there and try to get it out that way?
Eric Onick
1968 Chevelle Malibu
Big Block-475ci built by Mark Jones
Tremec TKO-600 5-speed
12 bolt Eaton Posi
TC Member# 2320
onick is offline
post #3 of 6 (permalink) Old Oct 31st, 04, 7:18 PM
Post
If this is a small block there are actually 2 tubes in the hole. There is a lower tube to keep the stick away from the rotating parts and then the upper tube goes in. I have had success in removing the broken piece by splitting one side of the tube with a small chisel then pulling it out with needle nose pliers. This is hard to do with the engine in the car.
63 Nova wagon
Philip is offline
post #4 of 6 (permalink) Old Nov 1st, 04, 6:57 PM
leo
Post
Find a sheet metal screw that will screw into the broken off part and then pull it out with channel locks or something like that.
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #5 of 6 (permalink) Old Dec 9th, 04, 4:24 PM
Post
used an easy out and it worked great! Thanks fo the ideas all.
oregonchevelle+ is offline
post #6 of 6 (permalink) Old Dec 12th, 04, 1:50 AM
Post
It happened to me to but I was lucky I just but the motor in so i took it back out took the oil pan off and hit the lower tube with a hammer and got the rest out then i replaced it. thats what i did good luck
srubydo is offline
This Thread is more than 5551 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
