"BACK FIRE BETTY" IN MY 454 - Chevelle Tech
post #1 of 3 (permalink) Old May 27th, 03, 7:23 AM Thread Starter
Post
Hello there,
I need a little support on my 72 chevelle.
Whats the best way to track down a backfire thru the exhaust?
the motor is probably a 73-74 454 with a new holley 650 with a
hei ignition. I've adjusted the timing to spec, 10 btdc then advanced.
brand new accel 8mm wires, and a cap and rotor, the plugs looked fine.
I get a back fire during accelaration(either a loud bang or a mellow putt-putt). Even idling I can hear
a slight mis-fire. I've only had the car a year and don't much of its history.
I'm wondering if it might be my hei module, cross fire thru the aftermarket wires
or a coil gone haywire. Is there a checklist I might follow to find the problem
THANKS IN ADVANCE
RODNEY - '72 CHEVELLE CONVERTIBLE
454 -4SPEED MUNCIE WHITE W'BLACK STRIPES
MATHER34 is offline
post #2 of 3 (permalink) Old May 27th, 03, 1:34 PM
Post
You have a pretty good list for starters...I would only add that you may also check the valve lash (specifically the exhaust side) to make sure it isn't too tight. If you are holding the valve off the seat a little bit, this can lead to a backfire and also to the valve burning up in short order.
Corey<br /><a href="
target="_blank">Corey's 67 Chevelle Page</a>
Corey872 is offline
post #3 of 3 (permalink) Old Jun 1st, 03, 1:41 PM
Post
Also be sure that when you adjust the timing the vacuum advance is disconnected, and plugged.
Best of luck,
Brandon
Brandon
70 Chevelle
68 Camaro
64 Olds Dynamic 88 Holiday Coupe
70mousejob is offline
This Thread is more than 6157 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
