HEI pickup module wireing - Chevelle Tech
post #1 of 2 (permalink) Old Jan 16th, 02, 6:23 AM Thread Starter
I can't remember how my pickup coil came apart. it has a Green wire and a yellow wire and the P and N terminals on the pickup coil. Does anyone know which one goes where? I can't belive I didn't write it down!
Got Chevelles?
Jeff Carpenter
65 Chevelle/65 Elky
67 Elky Project
Team Chevelle Gold #61
jeffc is offline
post #2 of 2 (permalink) Old Jan 16th, 02, 7:43 AM
If I recall, the two wires have slightly different width connectors on them. And, the module has different width blades that they go on. Take a closer look and see if they can be mixed, I suspect that they cannot. In one manual, it said that the green wire goes to the terminal with the green dot nearby. A Chev manual says to connect the white wire to the "W" terminal and the green wire to the "G" terminal. Now you know all that I do.Hope that will be useful.
JWagner is online now
This Thread is more than 6607 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
