strong exhaust smell - Page 2 - Chevelle Tech
post #16 of 20 (permalink) Old Jul 14th, 08, 10:52 AM
Rich
Re: strong exhaust smell
Originally Posted by Cat's ss View Post
Im having the same problem with strong exhaust smell while driving.It appears to be coming through the heat and air cond. vents. This is on a 72 ss small block with new exhaust to the rear.
If you are getting a strong exhaust smell in the interior check your exhaust manifold or header gaskets. It sounds like you have a serious exhaust leak at the engine.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is online now
post #17 of 20 (permalink) Old May 17th, 19, 5:51 PM
Did you ever get any responses to your exhaust smell post? I picked up a restored 72 Chevelle and I'm getting really bad exhaust into the cabin while I'm driving.
Lujama79 is offline
post #18 of 20 (permalink) Old May 17th, 19, 6:04 PM
Beth
This was 11 years ago.
67 Chevelle convertible, 138 vin, original 4 speed, bucket seats, 12 bolt, Marina Blue with black interior
nashville beth is offline
post #19 of 20 (permalink) Old May 18th, 19, 3:54 AM
Thumbs up Re: strong exhaust smell
pannetron likes this.
David
davewho1 is offline
post #20 of 20 (permalink) Old Jun 30th, 19, 8:13 PM
Russ
LOL on the skeleton! My '66 had a strong exhaust smell while driving with the windows down but not when they were rolled up. Turned out the PO had installed the trunk weather seal in the wrong orientation. After replacing that gasket correctly with the lip facing away from the inside of the trunk and adjusting the trunk to close bit tighter, no more exhaust smell while driving with the windows down. :-)
pannetron is offline
