radio cuts out on bumps - Chevelle Tech
  • 1 Post By Robinls5
post #1 of 7 (permalink) Old Aug 25th, 19, 6:52 PM Thread Starter
autumngold
Original am 8 track in my 70.When i hit small bumps the radio speakers cut in and out.Left side speaker will work then cut out and right side speaker will work,sometimes neither work till i hit a bump.Rear speakers cut out to.I posed this question here before but no answers.Anyone run into this before.
1970 ls-5 numbers matching
marcrose is offline
post #2 of 7 (permalink) Old Aug 25th, 19, 7:20 PM
Re: radio cuts out on bumps
One of my 70s ,,The plug at the back of the radio was not TIGHT.--
When you get use to it,,, You can reach under the dash and push the PLUG in and never take your eyes off the road!---
I re/did the plug in area on the radios,,, Now both radios are just fine.
LeoP likes this.
Robinls5 is offline
post #3 of 7 (permalink) Old Aug 27th, 19, 9:06 AM
Mr Bill
If it is one speaker and then the other then it almost has to be a loose connection like Bob said. I don't remember how many plugs are on the back of the radio. The AM/8track out of my car is sitting on the shelf in my garage. I can take a look tonight but it really doesn't matter. You need to get under there and push the connectors in all the way.
If it was a power or a ground issue the entire radio would be cutting on and off so I doubt it is that.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
post #4 of 7 (permalink) Old Aug 27th, 19, 8:02 PM Thread Starter
autumngold
Thanks for the reply guys.i found Its an internal fault,i can tap the radio with a screwdriver handle and make it cut in and out.I retensioned the terminals and cleaned the antenna lead., guess its time for a rebuild.Any suggestions on a good place.I see barrys 8 track service gets good reviews.
marcrose is offline
post #5 of 7 (permalink) Old Aug 27th, 19, 11:13 PM
leo
https://www.mikehaganantiqueautoradio.com/ He is in Pennsylvania and good luck!!
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #6 of 7 (permalink) Old Aug 28th, 19, 12:00 AM
Just an afterthought. The head itself could be loose as well. With something that old, it probably needs rebuilding. The pinch roller belt has to be on it's last legs!
Now if I could just find someone to rebuild my Muntz 4 & 8 track player. The 8 track repair guys won't touch it.
'66 El Camino, 327, 5 speed, 3.31 posi.
Custom painters don't screw up! They just add more graphics.
Moderator - nevadashooters.com
Tophog is offline
post #7 of 7 (permalink) Old Aug 28th, 19, 10:22 PM
leo
Bob, try my link above and good luck!!
Leo Paugh
A.C.E.S.#3731
LeoP is offline
