Hesitation ????!!!!! - Chevelle Tech
 2Likes
  • 2 Post By Shbradford
post #1 of 11 (permalink) Old Aug 23rd, 19, 12:41 PM Thread Starter
Hey everyone I have a small hesitation when I just hit the gas !!! It happens when I go from a stand still or if I’m rolling along at 5 or 10 miles an hour. The hesitation actually acts like the car is going to stahl for a second then takes off. It happens no matter if I go wot or just give it a little gas. ??? The carburetor is a Holley ultra street avenger 660 with vacuum secondary’s what could be causing this?? An advice or help would be greatly appreciated ! Thanks
Shbradford is offline
post #2 of 11 (permalink) Old Aug 23rd, 19, 1:07 PM
Jon N.
Re: Hesitation ????!!!!!
Accelerator pump isn't working the way it is supposed to.
Jon N.
dyno jonn is offline
post #3 of 11 (permalink) Old Aug 23rd, 19, 2:20 PM
Harry
You are probably leaning out between transitions. If you recently leaned out your idle, this reduces the amount of gas available during transition. Making your idle richer will help, but, may cause stink and eye irritation. If you have adjustable air bleeds, you could also decrease your low speed air bleed, this will give you more gas at transition.
Do you put in a new bigger cam ? If so, then, tuning is required.
Harry
hjdca is offline
post #4 of 11 (permalink) Old Aug 23rd, 19, 3:20 PM
Make sure your accelerator pump squirts as soon as you actuate the throttle. What is your timing set to?
oldcutlass is online now
post #5 of 11 (permalink) Old Aug 23rd, 19, 4:06 PM Thread Starter
I believe timing is 32 advanced. I am planning on putting in a bigger can very soon.
post #6 of 11 (permalink) Old Aug 23rd, 19, 6:24 PM
What does this mean? Is it locked out at 32, total timing is 32, initial is 32?
post #7 of 11 (permalink) Old Aug 23rd, 19, 6:51 PM Thread Starter
Total
post #8 of 11 (permalink) Old Aug 23rd, 19, 7:52 PM Thread Starter
At idle it’s 12 degrees advanced
post #9 of 11 (permalink) Old Aug 24th, 19, 12:27 AM
Ryan
As others have said, check accelerator pump. Ensure it is adjusted properly to where you get a shot of fuel as soon as you touch the throttle. That would be the first place I would look if I had the same issue. Holley has videos on how to do this.
1970 Malibu
383, 10.3:1, etec 200 heads, isky 280 mega, holley 770,
th350, 2600 stall,
12 bolt, 3.55 eaton posi
no time slip yet
just got out of paint
ppg arrival blue metallic
black SS stripes w/ blue pearl
2/75NastyNewbs is offline
post #10 of 11 (permalink) Old Aug 24th, 19, 9:08 AM
Bump your initial timing 4*'s more.
post #11 of 11 (permalink) Old Aug 29th, 19, 9:25 AM Thread Starter
Update : accelerator pump was set good. Went from a .028 squirter to a .035 problem fixed!!
LeoP and guitargeak99 like this.
