Intake Vacuum leaks? - Chevelle Tech
 6Likes
post #1 of 17 (permalink) Old Aug 12th, 19, 10:38 AM Thread Starter
Curtis
while tuning up my electric choke i noticed a sucking noise on the intake manifold. Its coming from four holes. Put you finger on them and its sucking, all four hole. Quick google and these are the four bolt holes on a edelbrock performer RPM 2 intake #7562. These four bolts are specified in manual as hand tighten only.
Mine have no bolts and you can see the gasket covering the holes between block and manifold. Never was a bolt in any of these four holes.
The question is this, is there any reason this would have been done intentionally? The car runs great, its dyno'd at 638 hp 652 torque. When i plug all four holes the idle drops way down and car barely wants to keep idling.
Curtis Chamberlain is offline
post #2 of 17 (permalink) Old Aug 12th, 19, 12:22 PM Thread Starter
Curtis
Re: Intake Vacuum leaks?
Anyone know of a good BBC forum or tech support type site? Im really concerned about this vacuum, leak issue
post #3 of 17 (permalink) Old Aug 12th, 19, 1:17 PM
Ya, put bolts in them holes! Unless those are some special race heads I am not familiar with , you are missing the four over port bolts. my lack of race head knowledge or not, clearly they are sucking unfiltered air, either from atmosphere or from the galley, so MUST BE squared away.
We dont know crap about BBCs here.
71350SS likes this.
post #4 of 17 (permalink) Old Aug 12th, 19, 1:24 PM
Just doing a quick search, it looks like some heads use them and some don't. My stock heads do. If your heads do not have holes, I bet the intake port shape doesn't match either. Pull the intake and match the gasket to the intake and head ports to see what is not right. Maybe your head has the holes and it's just the wrong gasket.
69SS454 is offline
post #5 of 17 (permalink) Old Aug 12th, 19, 1:32 PM Thread Starter
Curtis
They are Patriot 320 CC heads with rectangular ports. Thats all i know about them. This engine came from the builder, Ross Automotive Machine Lapeer Michigan built in 2010 and has been this was since. Made me think it had to be intentional. Maybe the gasket without a hole for those bolts was sufficient to stop leak for a time and its slowed gained the leak? Very strange however as it runs amazing, has tons of power none of the typical vacuum leak issues you would expect.
I ordered some bolts for it. Just hope I don't need to change the gaskets all together and remove the intake.
post #6 of 17 (permalink) Old Aug 12th, 19, 1:36 PM Thread Starter
Curtis
The heads and intake both have rectangular ports per specs. i guess i could poke through the hole and see if the block has bolt holes there.
post #7 of 17 (permalink) Old Aug 12th, 19, 2:31 PM
Even if they are the right gaskets and the ports match, they are leaking and need replaced. Pull the intake, get a new gasket set, and coat them with Gasgacinch Gasket Sealer.
69SS454 is offline
post #8 of 17 (permalink) Old Aug 12th, 19, 3:08 PM Thread Starter
Curtis
If i fix these leaks what are the adjustments that will need to be made to offset the adjustments made to counter the leaks? Just add more air at carb?
post #9 of 17 (permalink) Old Aug 12th, 19, 3:35 PM
Hopefully just open the throttle a little more. May need to go with smaller jets. Is this a recent problem or have you made air jet or other adjustments to fix it long ago?
69SS454 is offline
post #10 of 17 (permalink) Old Sep 7th, 19, 1:00 PM
Curtis, did you ever get this problem resolved?
67 Chevelle SS:
original paint, M20, & 3:31 posi.
Unrestored, but dreaming of doing so
guitargeak99 is offline
post #11 of 17 (permalink) Old Sep 7th, 19, 3:04 PM Thread Starter
Curtis
I have not. I got a new gasket just haven’t tackled reliving it yet. Hard to do all that work when it runs soo good lil
guitargeak99 and LeoP like this.
67 Malibu Sport Coupe
496 Stroker, 320CC Heads, 10:1, Demon 850 carb, HEI 65k, 16 Degrees base, 38 final, 638 [email protected], 696 [email protected]
Dakota Digita HDX, GPS, Fan Control
DSE stage 3 susp front and rear
Wilwood 6 piston brakes, DSE master cylinder/booster
DSE PS Gear, quick ratio, Ididit column
Bonspeed 20x10/19x8 with Michelin pilot sport 4s
post #12 of 17 (permalink) Old Sep 8th, 19, 12:06 PM
Yup, not one of us know anything about fat block Chevy engines, all I ever did with them was fix them after the experts made them work worse, work directly with Duntov at Chevrolet Skunk Works on engine development, and drag race a blown, injected nitro 605 inch one in an AA/Fuel Altered. Makes me dumb as a box of rocks about fat block Chevy engines.
Why not simply put the 4 bolts into the holes and tighten them up, that usually cures leaks at those 4 points. Worth a try, and no pulling the manifold back off if it works.
BTW, best way to find an air leak is to flow a low volume of UNLIT propane around a suspect leak. Engine will perk up a touch, exhaust will smell different, and NO residue on engine parts.
LeoP and blue_69_malibu like this.
Dave Ray is offline
post #13 of 17 (permalink) Old Sep 8th, 19, 8:21 PM Thread Starter
Curtis
There’s a gasket under the bolt holes, that’s how I know the wrong one was used. I could just drill out the holes I supposed but the fact it is the way it is I would feel better just removing it and making sure it’s right anyways.
I wasn’t implying anywhere didn’t know anything about bbc, I was just looking for another site I could search around on.
post #14 of 17 (permalink) Old Sep 9th, 19, 2:07 PM
Actually, to do it RIGHT, pulling the heads to drill the two holes per is the way to go, heads mounted on a milling machine (ONLY if you wanted to do it the right way).
Do you know if it is just the gaskets covering threaded bolt holes, or, are there no holes in the first place???
If ignorance is bliss, why aren't more people totally happy?
Dave Ray is offline
post #15 of 17 (permalink) Old Sep 9th, 19, 2:11 PM Thread Starter
Curtis
There’s holes just gasket covering them. I picked through it with a pick to confirm
