Clock shaft came out- 70 Chevelle - Chevelle Tech
  • 1 Post By LevonH
post #1 of 8 (permalink) Old Aug 1st, 19, 1:33 PM Thread Starter
Does anyone know if you can reinstall the clock shaft without removing the clock from the dash?
Name:	chevelle clock shaft.jpg
neaswa is offline
post #2 of 8 (permalink) Old Aug 1st, 19, 1:49 PM
Re: Clock shaft came out- 70 Chevelle
I had to send mine back to Instrument Repair Service in Holland MI, as it was one of their quartz conversions. Dont know on oem mechanical, but pros like them would know.
post #3 of 8 (permalink) Old Aug 1st, 19, 1:58 PM
I have the same issue and assumed I'd have to pull the clock (which is why it's still broken). I'm guessing there's some sort of set screw that came loose and you can only get to it from getting inside the clock.
If someone knows otherwise, I'd love to know -
jim
Jim's69Ragtop is offline
post #4 of 8 (permalink) Old Aug 1st, 19, 2:05 PM
I always thought they just screwed on. that looks splined/pressed. If it goes back in and almost stays through the hole in the lens, you could try a very tiny drop of removable Loctite and press it back in.
Pioneer4x4 is offline
post #5 of 8 (permalink) Old Aug 1st, 19, 2:56 PM
The quartz conversion is pinned in place somehow, so I sent it in. The stick never came out, only got "disconnected"
post #6 of 8 (permalink) Old Aug 1st, 19, 3:32 PM
Levon
Originals are splined like the picture. On the back side of the clock face is a spring and a gear. If you remove the clock be careful to not lose the 2 pieces. You can reattach the gear by pressing it back on and using some Loctite to hold it. I found that buying a quartz clock with the ticking motion was a much better approach. Original clocks are usually dead from the winder mechanism solenoid frying.
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is offline
post #7 of 8 (permalink) Old Aug 1st, 19, 6:13 PM Thread Starter
Thanks for all of the feedback. It sounds like the quartz unit is the way to go. Sounds like I have a winter project.
neaswa is offline
post #8 of 8 (permalink) Old Aug 1st, 19, 6:17 PM
Levon
Shouldn't take all winter. You can remove the clock without pulling whole whole dash if you are careful.
Levon Hovagimian
Team Chevelle #279
LevonH is offline
