Rochester 2 bbl spewing out fuel - Chevelle Tech
 5Likes
  • 1 Post By Pioneer4x4
  • 2 Post By mymalibubu72
  • 1 Post By mymalibubu72
  • 1 Post By Don B
post #1 of 7 (permalink) Old Jul 1st, 19, 10:23 AM Thread Starter
Jules
My carb spew's out a bunch of fuel after turning over. 1972 Chevelle Malibu 350cid, Rochester 2 bbl 2GV 7042114.
I'm looking for someone close by in my area ( Mississauga, Toronto GTA area ) that rebuild's carb's, I don't have the skill set for rebuilding carbs. I located a fellow in Ottawa, but I'd like someone closer.
Hard starting issue, the car had little driving time since I bought it last year. Followed a few threads here to help diagnose the root cause.
On a cold start it runs for 3-5 seconds then stops, as I crank it over a few seconds then I stop, a lot of fuel spews from the vent into the throat of the carb.
I believe it's either a dirty, worn or faulty needle valve and seat. Most likely dirty - Gosh dang, my fault for leaving the fuel tank low on gasoline! Probably sediment got through the filter. I've had this happen before with a 4 bbl holly on a 454, replaced the needle & seat and got up and running again, eventually replacing my old gas tank and fuel line filters.
I might as well get it rebuilt since I'm still planning the full restoration sequence and budget. If anyone has a referral, I really appreciate your help!
Many Thanks!
Best regards
Jules
mymalibubu72 is offline
post #2 of 7 (permalink) Old Jul 1st, 19, 3:05 PM
Re: Rochester 2 bbl spewing out fuel
Originally Posted by mymalibubu72 View Post
...I believe it's either a dirty, worn or faulty needle valve and seat. Most likely dirty - Gosh dang, my fault for leaving the fuel tank low on gasoline! Probably sediment got through the filter. I've had this happen before with a 4 bbl holly on a 454, replaced the needle & seat and got up and running again, eventually replacing my old gas tank and fuel line filters...
Probably varnish/whatever sticking in the car float, more than actual dirt. You can always try smacking it with a rubber/dead blow hammer while running. (pinch off the fuel line rubber to keep it from flooding with pliers)
We had a car do that once. It sat for years as well, the carb was OK after opening and just wiping everything in the bowl, but the tank took removal and cleaning to keep from clogging filters. I ended up putting driveway gravel, and tow chain in it, adding water, and shaking it around a LOT, then removed everything and rinsed/shook/rinse/shook until clear.
427L88 likes this.
Pioneer4x4 is offline
post #3 of 7 (permalink) Old Jul 1st, 19, 3:57 PM Thread Starter
Jules
Ed, I'll give that a try.
[ Added a few minutes later...] Wow! Ed you hit it dead on!! Did exactly as you said and it started instantly and is purring again.
I still need to have this carb cleaned/rebuilt to make it reliable in the meantime.
Many Thanks!
Best regards
Jules
LeoP and Pioneer4x4 like this.
post #4 of 7 (permalink) Old Jul 1st, 19, 11:14 PM
leo
not in Canada, but I recommend www.customrebuiltcarbs.com The shop is in NJ, good luck!!
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #5 of 7 (permalink) Old Jul 1st, 19, 11:18 PM
Many Thanks!
Best regards
Jules
A good saying I learned at a radio control airplane club of all places "hammer it to fit, paint it to match". Or like we say in I.T. now, give it a "kinetic adjustment"
But actually, I'd run some good carb cleaner through it, spray it full of gumout down the vent tube to dissolve that crap. And keep a close eye, and carry spare fuel filters.
post #6 of 7 (permalink) Old Jul 2nd, 19, 7:45 PM Thread Starter
Jules
Thanks for the help guys! Got a referral from Antique Chevrolet when i grabbed a new accel cable about 2 hours ago.
A local company in Oshawa that's been doing it for 49 yrs. Carburetor Rebuilders Co. Ltd. | Carbrebuilders.com
LeoP likes this.
post #7 of 7 (permalink) Old Jul 3rd, 19, 8:35 AM
Don
Back in the daywhen I worked in the Chevy dealership and those carbs were around it was pretty much standard procedure to replace the steel needle and seat in those 2BBL carbs when doing a tune up,or replacing the fuel filter.Any junk or dirt in the fuel bowl would get stirred up after the filter change and get in the needle and seat and they would flood like crazy.We would replace the needle and seat with a neoprene tipped needle along with a matching seat and problem solved.Probably took less than 20 minutes.
LeoP likes this.
Don B is offline
