69 427 - Page 2 - Chevelle Tech
 8Likes
post #16 of 22 (permalink) Old Jun 25th, 19, 11:12 PM
Re: 69 427
Originally Posted by 65vet56belair View Post
How would I isolate, canít keep running with popping
Check to see if the distributor cap on the HEI is sitting flat on the distributor.See if it shifted a little on the distributor body.That will make a noise as the rotor spins and hits inside the cap and it will run like caca too.
Will it stay running if you give it a little gas and hold the throttle open for a little more RPM's ? say around 1200 RPM ? Is there any change in the noise as you increase the RPM to around 1200 ?
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #17 of 22 (permalink) Old Jun 26th, 19, 12:06 AM
Levon
Is the HEI a real one or an ebay knockoff? Knockoffs have been known to cause grief. You have to make sure that the ignition is solid before moving on to fuel. No spark no run.
blue_69_malibu likes this.
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is offline
post #18 of 22 (permalink) Old Jun 27th, 19, 3:12 PM Thread Starter
Got it running, it was 2 issues, exhaust rocker on 7, came real loose and the same wire came off from steering rag joint pulling it enough to cause a issue, now just gotta fix vapor lock
71350SS likes this.
65vet56belair is offline
post #19 of 22 (permalink) Old Jun 27th, 19, 3:13 PM Thread Starter
Thanks everyone really appreciate
davewho1 likes this.
post #20 of 22 (permalink) Old Aug 4th, 19, 11:56 PM
Re: 69 427
Where can he find a real American HEI, built here by and American with American parts?
'69 Malibu
Not2Fast is online now
post #21 of 22 (permalink) Old Aug 5th, 19, 12:00 AM
Levon
Re: 69 427
Salvage yard? GM?
My question was to determine if the HEI is an off shore one that have a history of problems.
Levon Hovagimian
Team Chevelle #279
LevonH is offline
post #22 of 22 (permalink) Old Sep 7th, 19, 2:13 PM
Re: 69 427
Regarding your vapor lock issue - are you using any kind of plastic carb spacer or thick gasket?
67 Chevelle SS:
original paint, M20, & 3:31 posi.
Unrestored, but dreaming of doing so
guitargeak99 is offline
